What causes understeer???
My mini in this shit weather seems to understeer alot
Its got Yoko AO32 Tyres - Semi slicks,neg camber arms, poly bushed front end, Spax 14 way Adjustable shocks ( set to 6 on the front, so not to hard )...
Which will cause this to happen, As I need to get it sorted, Even at 20/30mph on roundabouts it understeers and its a right cunt
Understeer caused by a number of reasons including knackered front tyres, suspension too hard on the front, road conditions, excessive speed into the corner.
Never driven a mini so got no idea how they handle. Is it an older one with really skinny tyres?
Remember skids are caused by one or more of the following:
A - Accelerating too hard.
B - Braking too hard.
C - Cornering too hard.
If the road conditions are bad just make sure you corner gently and don't accelerate too hard.
One, the main reason, power and steering through 2 wheels = them to spin, when they spin they lose traction, thus causing the car to go in a straight line rather than turn.
Negative camber will only work in the dry when you're taking a mediumish corner pretty hard and well as it makes the whole tyre sit on the road, in the wet, round a roundabout, i'd be suprised if it wasn't aiding the understeer.
Fact that its a mini with tiny wheels also won't help.
Although in the wet, round roundabouts, I seem to get far more oversteer.
LOL!
Its the weather matey... your driving a VERY old car remember - don't listen to the bollox that old minis are the best handling car ever as it simply is true!
On a serious note - you've got modified suspension, have you had the car setup by someone that understands minis... ie not your local kwikfit!!??
Alex
Alex
Stavros
98
09-04-2008 11:41 PM
