Update
Old Dec 24, 2006 | 08:21 PM
BigErn's Avatar
BigErn
Default Update
If you have read my last couple of posts you will know Im having bother with my cosworth.
I have ruled out the TPs switch after much fannying on today, map sensor looks brand new too. It sounds as if timing is all to shit when it starts. Its still flooding up but will run for a few seconds if you hold about half throttle, it will rev then drop off rev then drop off a few times over before it cuts out. Then it wont start again for a few minutes and does the same when it does.
Timing looks like its out around 2 teeth out on exhaust cam pulley. Its got Kent pulleys on so Im only going from someone elses paint markings. No proper markings on the pulley.
Anyone experienced this before or able to give me a suggestion to try?
Please please please, Im sick to the back teeth of this. I just wanna drive her!
Thanks in advance and thanks to all those who have helped and suggested things so far.
Old Dec 24, 2006 | 08:25 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hmm. missed your posts pal, but always start at teh start...
What were the symptoms that led to this? Was it ok to start with, driving fine one min then bang, game over, or was it a gradual loss of performance, give me a little background info to save me reading lots of different threads...
Old Dec 24, 2006 | 08:26 PM
Harris.'s Avatar
Harris.
I had the same problem with my 3 door, i changed the cps sensor and it was fine,then it started playing up again ,would start rev up then cut out. Rang my mate who said it sounded like the ignition amp , Changed that and it was SORTED
Also put a new fuel pump and filter on,but that didnt make any difference
Oh and i changed the fuel pressure regulator
Old Dec 24, 2006 | 08:30 PM
lawnsy's Avatar
lawnsy
sounds like fuel to me.....blocked filter????
Old Dec 24, 2006 | 08:41 PM
BigErn's Avatar
BigErn
Na mate its overfuelling like a right bastard in number 4, I think.
Old Dec 24, 2006 | 09:44 PM
lawnsy's Avatar
lawnsy
what temp sensor at back of block..(blue one)
Old Dec 24, 2006 | 09:51 PM
Dave_Hay's Avatar
Dave_Hay
make sure timings lined up properly then if still problems look at fuelling i say.
Old Dec 24, 2006 | 09:58 PM
BigErn's Avatar
BigErn
Yes mate.
Am I right in believing you have a garage? I may bring my car to you if I cant get it sorted. Hopefully Stu will be able to work his magic on it.
P.s dunno if you guessed but Im the lad Mick got his white Cossie off, see sig (when I had it). Spoke to you at Micks place before.
Old Dec 24, 2006 | 10:04 PM
lawnsy's Avatar
lawnsy
not got a garage as such just a big garage on the back of house.........was a nice looking car that till mick got his hands on it....the lad he sold it to has still not got it running right .....still mixing water and oil....lol
at least one good thing came out of mick getting it i got the arp stud and nut kit off it......
Old Dec 24, 2006 | 10:10 PM
lawnsy's Avatar
lawnsy
you tryed changing the water temp???????
Old Dec 25, 2006 | 12:42 AM
coswurv's Avatar
coswurv
Hi lawnsy i used to own bigern's white cossie before him, i cant understand why it keeps doing that mixing oil and water i had it for a long time and never had a problem, im glad your making use out of my old stud and nut kit !! i personally think after speaking with bigern that there is a problem with the block being pourus or something along those lines
Old Dec 25, 2006 | 05:17 PM
lawnsy's Avatar
lawnsy
the head was fucked on it mate between the water and oil jackets and it got drove like this over heating all the time so the lad that got it off mick got another head for it like i told him to but he did not get the block skimmed......
Old Dec 25, 2006 | 09:18 PM
coswurv's Avatar
coswurv
It was decked 14 thou when i had the engine built so let him know this as having it done more might make it tight in the piston to valve clearance as it was already skimmed before i done it but cant remember how much.
Old Dec 25, 2006 | 11:17 PM
BigErn's Avatar
BigErn
I got the block skimmed again myself when I re built it so I wouldnt do it again. I told mick that the piston liner had cracked on me but I only got one replaced, so my guess was another liner had gave up cos it was just as old and weak as the first one. I was gonna put a block in it to be safe. If Karl wants one I can get him a standard 205 Cosworth block from a mate.
Old Dec 25, 2006 | 11:19 PM
BigErn's Avatar
BigErn
There was sod all wrong with the head, was corroded when I got it but a skim sorted it and it was pressure tested fine. Dunno if he had it done since but I really doubt thats what it was. He needs to get the block pressure tested and that will reveal his problem.
Old Dec 26, 2006 | 09:13 AM
coswurv's Avatar
coswurv
I agree mate everything else seemed spot on
Old Dec 26, 2006 | 06:28 PM
lawnsy's Avatar
lawnsy
karl recons he had the head and block tested but yo know what he is like....
TPM961
Jan 15, 2018 10:50 AM
pabloXR
Sep 21, 2015 12:42 PM
