cosworth plenum elbow mods?
#41
Originally Posted by JayCos
dan if you use a spacer is this better than a swedish copy ?
Hi Jay,
i cant say, but i would say my inlet is at least as good a swed inlet.
Also, Rod runs a Rs500 inlet, and that speaks volumes to me.
Originally Posted by Bosch-Man
...what a pointless exercise
...there is a plenum cover for any power requirement...messing around may increase flow but how many get the fueling checked after!!!!
2wd cover = 440bhp
4x4 cover = 460bhp
eec4 cover = 520bhp
RS500 cover = ???
Swedish plenum = MAXIMUM
..all approx
..dont like the look of Baskys.
2wd cover = 440bhp
4x4 cover = 460bhp
eec4 cover = 520bhp
RS500 cover = ???
..all approx
That go with out saying tho, if you fit a new inlet, say a 2wd to a 4wd, it will be the same.
And Rod uses a 500 inlet, and we all know what he's managed.
Originally Posted by Baldy Butch
Originally Posted by Fiecos Dan
I can do it.
What are you looking for?
the same thing as what jenspeed do
![](https://img.photobucket.com/albums/v331/capri-rs/my%20car/telefonbilder089.jpg)
But i cant flow check them, and you will need a remap on over 50% throttle.
#42
Hi Jay,
2wd cover = 440bhp
4x4 cover = 460bhp
eec4 cover = 520bhp
RS500 cover = ???
..all approx
2wd cover = 440bhp
4x4 cover = 460bhp
eec4 cover = 520bhp
RS500 cover = ???
..all approx
I can do it.
#47
Basky...its not that...its the fact i cant see it taper like the Swedish one does which surely causes unequal flow to the cylinders?
you would be surprised how good this mod is
baldy butch do you have a msn?
have some more photos of the inside
#48
but its not sweedish
done afair few track days with the plenium and no probs ,
even pushes cars on greys,although im on greens
surely you would only have to flow test when using all its potential
and 350bhp @20PSI is nowhere near
some of the other pleniums dont taper either,seen one on the texaco one in norway with a much squarer monifold
#49
#50
Originally Posted by Basil Fawlty
price on doin it dan ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Price depends on, if i do 1 or more at the same time?
If you want it finished, or just left as the one pictured?
And if you will supplie the plenum to modifie,
but it will need a skim, and P+P back to you, thats £25 on its own.
#57
I have noticed boost fluctuation between 5000rpm and 5800rpm after I did this modification to my 4wd plenum cover. It could be some other thing also since I changed my cam timing and had my cylinder head ported, but the first thing that came in to my mind was that maybe my modification didn't go so well. Has anyone else noticed this kind of thing? The fluctuation isn't bad, but it is noticeable since my boost signal is almost flat until that point and after this rev band.
JK12
33
26-04-2021 12:09 PM
Escortdriver1
05-08-2015 12:45 PM
Escortdriver1
31-07-2015 02:36 PM
