wastegate chatter on a t25 escort cossy
01-09-2004, 09:55 PM
will i get any wastegate chatter if i fit a cone filter to my small turbo escos, bored of the quietness of the car now and don't want a dumpvalve
01-09-2004, 09:57 PM
01-09-2004, 10:02 PM
I would doubt it as well, as wastegate chatter does not exist
you might however, hear the turbo surging
01-09-2004, 10:04 PM
Whassup
how do get that chatter sound then ??
01-09-2004, 10:07 PM
i get that "chatter" sound on mine and i run a k+n cone filter
01-09-2004, 10:08 PM
Whats standard boost on these about 10 - 11 psi
01-09-2004, 10:13 PM
8ish
cheers peeps. boost gague is next on my list cos the standard one is pretty useless.
01-09-2004, 10:16 PM
8ish i run 10psi on cast pistons and 10.5.1 compression for some reason i thought they were higher.
Oh well you live and learn
01-09-2004, 10:18 PM
Whassup
01-09-2004, 10:20 PM
10.5:1?????? are you sure???
std c/r on cossie is 8.1:1
01-09-2004, 10:24 PM
No, not cossie Sierra dohc 8valve turbo 10.5.1 compression 10psi 200hp.(T25)
Ł10.00 to fix when anything goes wrong / Ł20.00 if you need a second hand complete engine.
01-09-2004, 10:30 PM
swap u 4 a 3 door that chatters well
01-09-2004, 10:32 PM
Quote:
funny really as he just sold a ringer to get the escort
01-09-2004, 10:35 PM
nice 1 ary, i'll have it back as the escort is boring
01-09-2004, 10:36 PM
I did on my small turbo with cone
01-09-2004, 10:38 PM
may be a ringer, but the back end is straight
01-09-2004, 10:39 PM
cheers dunc, what filter did u have. i'm thinking of a pipercross foam jobbie
01-09-2004, 10:42 PM
doh walked into that one
or is that reversed
here u go ary, pic 4 ya
01-09-2004, 10:48 PM
01-09-2004, 10:52 PM
DEYTUKURJERBS
They have them lil recirc dumpvalve things attatched to the compressor housing on T25 esc cossies dont they? Will need to blank that off, get a cone filter, and should have decent-ish chatter
nice 1 AJ, does the k&n come with an adapter plate for the filter
01-09-2004, 10:56 PM
not that i know of m8 got mine of a user on here its the ggr item
01-09-2004, 11:01 PM
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
FlashRS
14-09-2015 12:36 PM
Billy_RS
15
05-09-2015 12:04 PM
Vincereese
18-08-2015 03:57 PM
stickyslick
14
10-08-2015 06:27 PM
