oh dear headgasket just blew.
Old 10-12-2006, 10:11 PM
m_nettleship
m_nettleship's Avatar
Default oh dear headgasket just blew.
yep loads a white smoke, misfiring, and 1500 miles after a rebuild oh well.
Old 10-12-2006, 10:14 PM
MAD EVO 4
MAD EVO 4's Avatar
Not good mate
Old 10-12-2006, 10:17 PM
radiant red
radiant red's Avatar
gotta be some reason behind it mate
boooooooo
Old 10-12-2006, 10:20 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
what engine/gasket?
Old 10-12-2006, 10:49 PM
BigErn
BigErn's Avatar
Not good mate, my 2wd Sapph had the small issue of cracking the block 1154 miles after a rebuild. DOH!!!
Hope it is just the gasket for you mate
Old 11-12-2006, 08:40 PM
m_nettleship
I have allways had concerns, about the head. it just went like that. misfiring , then the smoke. My engine builder says that after wking on cossies for 25 years, hes never had a head gasket go on him. makes me think hope its not mega buckes.
Old 11-12-2006, 08:47 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
gaskets usually go cause of det, esp if they new and have been torqued down right.
they usually made to be the weak link, the mega cyl pressure det gives has to smash summat, rather it be head gasket than conrods or pistons.
was it properly setup/mapped?
Old 11-12-2006, 09:00 PM
m_nettleship
only 17psi of boost. explain that again mate in greater detail. cheers.
Old 11-12-2006, 09:07 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
basically imagine the peak cyl pressure inside your engine, it is literally hundreds , if not thousands of psi.
so much so that a few psi extra boost is insigificant as a pressure, ie the pressure itself wont blow the gasket.
but when an engine is detting (often due to that extra boost pressure not being mapped for properly) the peak cyl pressure rises hugely (upto 500%), thats what blows gaskets etc.
when people say too much boost blew the gasket, its rarely the actual pressure when running right, its the pressure when its detting.
DavidK
27-09-2015 02:55 PM
JoeyBoyden
20
22-08-2015 03:23 PM
RockinRein
19-08-2015 07:08 PM
Quick Reply: oh dear headgasket just blew.
