how to get a reliable 330-350bhp from cossie?
Old 09-12-2006, 12:05 PM
banhambuilt
banhambuilt's Avatar
Default how to get a reliable 330-350bhp from cossie?
i keep reading about all these colour injectors for a given bhp,it`s all a bit confusing to me really .
what i am after is a reliable 330-350 bhp in the rs200 with a 4x4 cossie engine.
engine has done 27000 miles,will it need a stripdown at this mileage?
heads never been skimmed (measured it at 139mm as per ford spec)
what will i need regarding turbo,injectors,actuators,chip etc.
please excuse me if this thread has been done a million time before,but i am a numpty for remembering things
thanks
dave
Old 09-12-2006, 12:22 PM
R5FORD
R5FORD's Avatar
green injectors...stage 3 chip...3 bar map sensor...t34 turbo o a 63 housing will get 380 bhp... i belive
correct if i am wrong
Old 09-12-2006, 12:47 PM
JamesH
JamesH's Avatar
This will get 350 on the right chip, and be very reliable, so just what he wants
Old 09-12-2006, 12:49 PM
banhambuilt
thanks for that
how about prices?
can you get a decent priced good t34?
thanks
dave
Old 09-12-2006, 12:52 PM
charlie luciano
charlie luciano's Avatar
Originally Posted by banhambuilt
thanks for that
how about prices?
thanks
dave
Turbo should cost around £700
Luciano
Old 09-12-2006, 01:14 PM
xr2i-carl
xr2i-carl's Avatar
Old 09-12-2006, 01:35 PM
R5FORD
R5FORD's Avatar
im learning
Old 09-12-2006, 01:38 PM
KSA-Cossie
KSA-Cossie's Avatar
Whats the max power you can get from a t34 with .48 housing then ?
Old 09-12-2006, 01:39 PM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
.48 housing will get ya 350+....with a bit quicker spool up....but a .63 u will have more if wanted...
Old 09-12-2006, 01:41 PM
pete mcrash
....now ya gona start something.....my pal got 383bhp with light blues
Old 09-12-2006, 01:47 PM
xr4x4rs
xr4x4rs's Avatar
i would put a grp a head gasket on at the minimu
regardless of how many miles your engine has done
start chucking 25psi through it the head gasket is going to shit itself
but other than that
greens
3 bar
t35 .63 ex
be worth upgrading the intercooler
and as the said the rite chip
Old 09-12-2006, 02:15 PM
pete mcrash
nobody has said...greens and standard t3...if he wants 330 that is, and i've got a M.S.D chip lying about somewhere
Old 09-12-2006, 02:24 PM
banhambuilt
all good comments,thanks
so i would be running about 25psi?
i already have an uprated intercooler i had custom made for my old rs200,so that should be ok.
would it be best to fit a group a headgasket or similar?
uprated (arp) head bolts/studs
as post above can you really get 330 ish out of greens and standard t3,if so for a standard ford part that`s brillant,100+ bhp and still with a stock turbo (if correct)
dave
Old 09-12-2006, 02:35 PM
pete mcrash
u calling me a liar..... t3 greens (803's) 3bar 22-23psi...320-330 bhp
Old 09-12-2006, 02:53 PM
Nash
Cake lover!
Nash's Avatar
dave
My mate from Nantwich was running greens and standard T3 was around 300bhp but really was pushing it. He added a T34 with a .55 ex[i think] and its defo quicker than before and he prefers it as feels alot stronger. i would personally go for a T34 instead of putting that much stress on a T3, but it's upto you.
As for who to get the chip and other bits off, i would use Stu at MSD thats who i will be getting to do mine when i have a bit more cash. As for turbo's for sales section in here is usually pretty good.
Old 09-12-2006, 02:54 PM
KSA-Cossie
KSA-Cossie's Avatar
Cheers pete.
Old 09-12-2006, 03:25 PM
pete mcrash
forgot to say....reliable and cosworth are words that dont mix....
Old 09-12-2006, 03:26 PM
lamb chops
lamb chops's Avatar
As said Dave you could keep the T3 but would be pushing it at 300 and wouldn’t expect it to last that long. T34 would be the best option, I would get a .48 housing and have the quicker spool. You see good second hand ones on here for about £350 400. If you live near Blackpool area I would recommend a trip to MSD for a setup and perhaps coil packs and closed loop lambda for the ultimate
Internals wise Grp A head gasket and job done unless you want closer to the 400 BHP mark but then you will be pushing it on the standard dif and gearbox. A genuine 330 with the cars light weight and it will be a proper weapon.
Old 09-12-2006, 03:30 PM
thedaddie
thedaddie's Avatar
Default stage 3 parts?
i have a turbo i no longer need which is for stage 3 if your interested
i have had the turbo for 4 years and has been sat in the loft never used.
fully rebuilt by i think off the top of my head turbo dynamics so is as new
it is a t34.63 also comes with a silicon boost pipe and a grp a k&n air filter
price is £750
if you was to take this i could also get you injectors at trade price as my dad works for bosch
i was going to use this turbo but my car needs new sills and as i have just got married and had a kid its drained my funds.
i'm running a standard block/head with a tripple layer gasket
light blue injectors
alloy rs500 intercooler
grp a coil
spec r grp a oil seperator
t34.63
large air filter
running 356bhp during the summer heat wave so could pull another 10-15bhpon a normal day
so as you see you dont need much to get a lot of power
here is a printout after it was setup
here is my car 4wd cossie cabrio
i like your project looks cool good luck with it
Old 09-12-2006, 03:36 PM
R4N SS
R4N SS's Avatar
Default Re: stage 3 parts?
now that i like any more pics?
Old 09-12-2006, 05:09 PM
DazC
DazC's Avatar
What about the word RELAIBLE in the topic title?
Once you have got the power you need the engine to hold together.
I suggest a decent radiator and intercooler ensuring the cooling fans work,
An uprated breather,
A new engine wiring loom,
Uprated head gasket,
New fuel pump,
New fuel pressure regulator,
New coolant, boost and signal pipes,
Full set of new sensors.
Just to mention a few pointers
Old 09-12-2006, 05:52 PM
banhambuilt
[quote="DazC"]What about the word RELAIBLE in the topic title?
New fuel pump,
Just to mention a few pointers[/quote
the bits mentioned above will all be new anyways,as i bought a suspension,engine,box package,i don`t have much choice but to buy new.
dave
Old 09-12-2006, 07:23 PM
Eagle
Super Moderator
PassionFord Gold Member (Male)
Super Moderator
Eagle's Avatar
im running 24 psi on a standard headgasket and have been for around a year
Old 09-12-2006, 08:37 PM
Bullett
Bullett's Avatar
depends on the treatment mate. i was 330bhp on t3,bajoo chip,dark greens,3 bar,-31 and standard 4x4 intercooler.ran that for a year then went t34 to go up to 350 and the engine has 148k on it now and original bar the headgasket upgrade.
Old 10-12-2006, 01:35 AM
SS1
SS1's Avatar
thedaddie
Old 10-12-2006, 02:11 AM
Nookerhead
Nookerhead's Avatar
Think im missing something here! Reliable and cosworth definately dont go hand in hand,
Old 10-12-2006, 02:14 AM
Nookerhead
Nookerhead's Avatar
Hows about RELIABLE!!
Old 10-12-2006, 06:06 AM
MARCOSWORTH
MARCOSWORTH's Avatar
How many miles
Old 10-12-2006, 07:57 AM
Mr Brannen
Mr Brannen's Avatar
That convertible is awesome by the way
Old 10-12-2006, 11:52 AM
DazC
DazC's Avatar
Twat! I was in a rush! Thought I had spelt it properly!!
Old 10-12-2006, 12:21 PM
foreigneRS
Testing the future
foreigneRS's Avatar
if you buy a t34, try and get one with a maram shaft so that you can run antilag - if your car looks like a rally car, it should sound like one too
Old 10-12-2006, 12:51 PM
pete mcrash
yes to the above.....
Old 10-12-2006, 08:30 PM
Nookerhead
Nookerhead's Avatar
Dont rush!!
Old 11-12-2006, 09:35 AM
banhambuilt
maram shaft?
what does that do over the standard shaft then?
concerning anti-lag,i thought you have to run a p8 for this?
what does it sound like? anything like wastegate chatter?
cheers
dave
Old 11-12-2006, 09:55 AM
charlie luciano
Default 330-350
If your car is 4x4 buy yourself a decent gearbox
Luciano
Old 11-12-2006, 05:27 PM
foreigneRS
Testing the future
foreigneRS's Avatar
maram shaft?
cheers
dave
a maram shaft is made of a different material to a std turbo shaft and can take the shock loading (don't know if the heat also comes into play) caused by antilag
you do not need to run a p8 for antilag. it can be done with L8.
what does it sound like? a proper rally car from the early 90's
Old 11-12-2006, 05:45 PM
banhambuilt
anything like this?
http://www.youtube.com/watch?v=puGCda4ThvU
sounds like the bottom ends fallen out
dave
Old 11-12-2006, 06:48 PM
Little_Hoss
Little_Hoss's Avatar
yep thats anti lag
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: how to get a reliable 330-350bhp from cossie?
