wobbly wheel problem
just trying to diagnose a small problem with my car, 4x4
i noticed when the mot guy was moving it around at the garage, when he braked the front wheels seemed to move forward an inch
i have also noticed i get rather nasty vibration under light braking from about 60mph. It causes the steering wheel to wobble pretty violently.
also if i am moving, very slowly in traffic, and brake very very gently to come to a stop, you can feel the brakes kind of 'pulsing' like they are warped. you know...like one part of the disc is more effective than the next part?
the car is polybushed front and rear, apart from the front tca's i think.
any suggestions?
any suggestions?
are you sure the wheels moved forward? not inwards to the rear of the arch? i would check all the bushes mate. might be worth clening the discs up before you replace them. may just be a build up of material on the disc.
yeah, that would make more sense i spose, didnt think before typing
just noticed the wheels moving when he braked.
will check all the bushes this weekend, just wondering if there are any 'common' ones to look for
Originally Posted by AlexF
Sounds like classis warpped disks to me.
There is some movement in the wheels when braking or accelerating if you have bushes.
Alex
Alex
i kinda guessed the discs might be warped, just wanted to check the other suspension parts before, going out and buying new discs.
Originally Posted by NIL 7717
if its moving back and forth its the track control arms.i put money on it.
i have 2 sets as the ones on there were replaced not long before i bought the car.
i take it they have a bush where it meets the subframe, and one through which the ARB passes
need to check the bottom ball joints too as the front drivers wheel can knock on hard bumps
Jeebus
Testing the future
Originally Posted by Phil
I thought it was the ARB on the Cossie setup that controls the position of the wheel in the arch (in terms of forwards and backwards movement anyway). The TCA just keeps it spaced out width ways the right amount. i.e. if you disconnect the ARB there is nothing holding the wheel in place properly and it will swing forwards and backwards?
quite normal for std bushes, even when new, to see the wheel move. scary really. easily eliminated with polybushes.
Resident Wrestling Legend
there was a case where a sierra failed on the arb bushes, the garage fitted new bushes, it sitll failed
but if it means swapping the amrs about it's better than having hte jint fall apart and kill the car
inners are not as important but if you have them get them done at the same time, pain in the arse, proerply
don't forget to get the tracking done aferwards
had a look at them yesterday and cant see anything wrong with them
think ill remove them and replave the inner and outer bushes with poly ones
assuming they are available?
Originally Posted by gingeRS
Originally Posted by dojj
poly tca bushes?
i think they will last longer tha peole will remember that a sierra was a car mate![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
so i think it's fair to say it's going to outlast the car
Ben26
27-08-2015 08:56 PM
bassboy
08-08-2015 10:21 AM
