Operation 400bhp std comp - help needed
Hi guys,
The next cosworth journey that I am about to undertake is the 400bhp+ engine. the figure is chosen as a benchmark. Slightly over is fine, slightly under misses the point.
I had a fascinating chat with Chip and a couple of others at the last WSM meet, and I want now to refine my shopping list of bits, and stuff so that I can work my way to this target.
To keep it simple, questions are posed as follows. Further info is below...
1. What work needs to be done to the head itself? internals below
2. Standard cams up to the job? If not, any recs?
3. What valves, and what followers?
4. The block currently is 200 block, mahle pistons (std comp), +0.5 oversized to be sure, all fully balanced bottom end. Runs cometic 3 layer gasket with no trouble.
5. Turbo is currently T35. Proposing to change for a T38, as per chat with Chip and Doug.
6. Fuelling will be from the newly acquired Group A pump. What about regulator - does this need anything? Also which injectors?
Once I have the engine essentially built, I will prob take her to one of the tuning chaps for a live map, which it will clearly need. Anything else I have missed?
Thanks all in advance!
Originally Posted by JjCoDeX75
Hi guys,
1. What work needs to be done to the head itself? maybe porting it mild, not nesecery tho
internals below
2. Standard cams up to the job? If not, any recs? BD-14 in
3. What valves, and what followers? STD. hydraulik
5. Turbo is currently T35. Proposing to change for a T38, as per chat with Chip and Doug. t38 a an minimum
6. Fuelling will be from the newly acquired Group A pump. What about regulator - does this need anything? Also which injectors? light blue or grey if std management std regulator
Once I have the engine essentially built, I will prob take her to one of the tuning chaps for a live map, which it will clearly need. Anything else I have missed? exhaust? manifold? i/c?
internals below
what makes you want to stay with standard comp?
Am I misguided? If so, I can be persuaded to change the pistons.
JJ
Hi guys,
internals below
internals below
The exhaust currently installed is the Magnex that follows broadly the original system (ie splits then rejoins) with the 3" tailpipe (if relevant).
The manifold is the original 2wd, which I was led to believe was the best option?
Ref Management - I have an S8 that I may use, or possibly a L8. Either way, it will need to be live mapped.
JJ
is the engine being fully stripped/or just head off? if the latter pistons can HANDLE the power your after,standard cams with standard followers,T34 or as stated T38,bit of porting WOULDN'T go a miss,400 or 403's injectors I'd go for the latter or even some Siemems! there HAS been a few with standard comp with 400+!!
send a pm to Tiff!
send a pm to Tiff!
Hi guys,
internals below
internals below
JJ
Hi guys,
internals below
5. Turbo is currently T35. Proposing to change for a T38, as per chat with Chip and Doug. t38 as an minimum
internals below
JJ
This is problably the cheepest option to get it to about 400brake, and still drivable, so go for it
send a pm to Tiff!
send a pm to Tiff!
Agree with porting - chip said the same. I have a spare head, so the plan is to prep the other head, then put on when ready.
JJ
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
I have a completely standard engine and head fitted with a UT T38 and a Swedish 'style' plenum. Live mapped on L8 with Siemens 83lb injectors by MSD. Made 397bhp on Alan Jefferies Dyno Dynamics rollers
JJ
i have a UT t38 but it's on a well overspecced engine to be honest.....making 450ish bhp now,so it's pretty much on it's limit.a T34.63 will do 400bhp,so don't discount it totally.
if i were you i'd go for a ported head (Karl does a low lag stg 1 head that is very very good,i had one on my last cossie)
i'd get the standard pistons pocketed as you'll be changing cams (although these probably won't be wild cams,but it's a good mod to do in case you go for lairy high lift cams in future)
greys will be fine,L8 would be a good option to get a good smooth economic drive
INteresting what you say about the porting. To be honest, I would prefer to do the porting with my guys that I work with locally only because I can be more hands on, but will need some help on specs if anyone knows.
JJ
a live map from karl (or others) will give you a real 400bhp on .63 t34 on greys or above on std pistons (not even oversize for extra capacity
) and cams
JJ
Originally Posted by Baldy Butch
did a engine for my mate a while back and he had a totally standard bottom end, pair of bd10s, ported head, t34.63, greys, 10mm plenum spacer
that made 412 bhp
that made 412 bhp
JJ
low comp it
There must be advan and dis to each. Anyone care to venture an answer...
JJ
if u keep the comp higher it will make it more reponsive off boost and as ur only gonna run 400 bhp max it will be under no strain what so ever
AAAAAAAAAH one of the most talked about power outputs in recent months after the huge easily obtained 500bhp mark!
never read full post but heres my 2pennys worth on a genuine 400bhp motor................
i ALWAYS use 205 blocks, but not cosworth ones as they have always been thrashed to death.
try and get a low mile 2.0 pinto EFi Auto granada block/engine, i find 205 ones last longer for some reason?!
i always run standard 8:1 "or there about" compression style engine rather than low comp 7.2:1/7.5:1 on pocketed pistons due to the shyte lower end power loss, rather than a large port head go for a slightly re-shaped inlet and polished head, i find this keeps up good torque figures in the midrange.
for genuine 400bhp "on the cheap" you need BD10/14`s and verniers, setup is secretive
and needs a profesional to set it up!
fueling needs (bosch 403) 4 xgreys or (webber 400`s) 4x light blues fed by a gpA Bosch (044) fuel pump
air supplied by minimum of a T34 with .48 housing running 24psi through a 4x4 intercooler or idealy T35 with same boost running .63 housing and/or 500style intercooler.
all above running the obligortary single pipe from turbo back stainless exhaust and free-flow panel filter or K+N style cone filter with cold air feed.
hope this helps!
hope this helps!
Guest
Posts: n/a
Intrested in this power as its probably all I could afford if I ever venture back to cossie ownership
Originally Posted by Matt J
Not doubting, just intrigued, most people seem to think a T34 .63 with its neck wrung at 2 bar is needed for 400bhp, can it be achieved on lower boost with a smaller housing?
P.S 2 BAR is 29.4psi (14.7psi = 1 bar) thats a lot of boost for a turbo like that, expect a very very short life out of the turbo!
hope this helps!
hope this helps!
hope this helps!
hope this helps!
The car runs an RS 500 intercooler, but a MAgnex system that splits and then rejoins. I hope I dont have to loose this, as I am hugely reluctant to change this unless absolutely necessary.
Ref the cams - so standard cams are not up to the job then. As you say, the trouble is that you get into the black art of setting up cams.
Turbo wise, I was probably going to go for a TT T38.
thanks all for the input
JJ
TT T38 8:2.1 comp , 14s head work, greys, mahle pistons pocketed , 450 bhp very good set up for road use off boost and on, pulls like a train to the 8.5k limiter !!!!
stick to the comp or raise it, don't lower it !!!
T34 will give you 400 although its close to its limit...
Standard Head and cams wont do 400bhp.
Karl told me most would be around 360bhp.
with any cams more than BD10 the pistons must be pocketed.
Why the obsession with bhp? your car might make 400bhp but be about as drivable as a squashed slug!
mine is just under 400 bhp,
200 block
6.9.1 cosworth racing pistons
standard head
bd14`s
t4 hybrid
mongoose straight through
greys
still on level 1 ecu(not for long)
my head is on its last skim and my pistons aint pocketed and the bd14`s run fine
200 block
standard head
bd14`s
t4 hybrid
greys
Originally Posted by SapphyMike
Standard Head and cams wont do 400bhp IS possible Karl told me most would be around 360bhp.
with any cams more than BD10 the pistons must be pocketed. NOT TRUE
mine made 429 bhp on the rollers.
standard engine, T4 and greys and mapped by Karl, 28lbs of boost..oh.. its flat out on the greys too,not too sure what they run out at.
All been built and used a cometic gasket.
well my cos has a tt t38,ported head and comp raised to 8.3,bd14 and standard cam which makes a nice responsive engine.Oh black siemens injectors swedish style inlet rs500 cooler etc.
i made 411 bhp on well lane so that doesnt count,right dicko??
but was only showing 26psi as the rollers werent loaded up enough,i normally run 30+psi.
