NO SPARK ON ESCORT COSWORTH ANY IDEAS
it s a l-reg monte carlo big turbo, it ran fine last saturday when i had it out, went to it today to do a few winter jobs as you do and wouldnt start
no spark, turns over, fuel pumps working fine,
changed, crank sensor, ignitioin amp, coil, phase sensor looks fine,
i put a live straight to positive side of coil from battaery and starts and runs fine until i remove it
any ideas
any ideas
Team HOTHOT!
Standard ford immobiliser playing up is a good place to look at ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Then check the multiplugs for the engine harness on the chassis legs - if they have not been cut out already that is
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
we checked all the plugs today along with everything else we could think of there was only 0.7v getting to the coil so we checked the alarm that is fitted & it has no immobiliser wired
we will have to check the wiring again next week
i think the ford imobiliser cuts the fuel pump and starter motor and there both fine
anyone know if theres is a relay to power the coil
The coil 12v is not thru the ECU good news eh, Its also before the engine loom multi plugs so more good news, Its thru a Ignition fuse and relay and any after market immobilser. Standard immobiliser cuts fuel pump relay. Check for corroded fuses and dodgy immobilisers. Got Drawings if u need em
cheers
my car done, some thing like that, although it did run just cut out when it wanted, the live is an ign live from the fuse box, i just ran a new live rather than strip the loom to find it !!
job done
job done
jessie_rs
11
03-06-2019 04:57 PM
Escortdriver1
31-07-2015 02:36 PM
