Problems already!
Old Dec 3, 2006 | 03:06 PM
  #41
PeterLucas's Avatar
PeterLucas
Mine was also on number 4 .
Do you have odd noises when it misses? like an exhaust blow. I could hear the air passing the exhaust valve sounded like a leak but it didnt have one
Old Dec 3, 2006 | 03:29 PM
  #42
radiant red's Avatar
radiant red
in regards to rocker cover gasket throw the fucker away and use silicon i never looked back
Old Dec 3, 2006 | 03:52 PM
  #43
BigErn's Avatar
BigErn
I been messing about with it today and I swapped number 4 injector with 2. Its better but not 100%. Wondering if it needs its injectors cleanng properly, its been stood in a garage for 2.5 year before I got it.
Old Dec 3, 2006 | 03:53 PM
  #44
radiant red
possible sticking valve??
Old Dec 3, 2006 | 04:06 PM
  #45
BigErn's Avatar
BigErn
Just out of interest Radiant Red, what exhaust sytem are you running your Sapph on? It sounded lovely at the well lane rolling road day.
Old Dec 5, 2006 | 04:15 PM
  #46
PeterLucas's Avatar
PeterLucas
Did this get sorted?
Old Dec 5, 2006 | 05:35 PM
  #47
BigErn's Avatar
BigErn
Nope its still not right.
Had it in today and it was running stupidly rich, managed to get the co down to 6. Been advised to get the injectors cleaned and a set up on the rollers.
Old Dec 5, 2006 | 05:39 PM
  #48
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Dont get it setup on the rollers. Take it to someone who knows what they are doing who can listen for det and check fuelling on the road as you cant properly re-create road conditions for load on the engine on the rollers. Thats my advice anyway. It would seem the only thing rolling roads are good for is giving you an in-accurate display of power you either have got or isnt measured correctly
Old Dec 5, 2006 | 05:45 PM
  #49
BigErn's Avatar
BigErn
Can you recommend somewhere CossieRich mate? Ideally in the North East or a doable one day journey for me. Cheers bud
Old Dec 5, 2006 | 05:50 PM
  #50
Lambchop's Avatar
Lambchop
PF Idiot Sniper
How far to blackpool mate? Stu@MSD would diagnose for you no bother.
Old Dec 5, 2006 | 05:51 PM
  #51
CossieRich's Avatar
CossieRich
Erm.....
My geography and locations within England are shit lol
Seeing as you said North then it has to be Stu at MSD really. He is in Blackpool. Or if you wanna come further south then Karl Norris is in Coventry I beleive.
Or further south still you have Mark at M.A.D (J10 M4) or even further south near essex you have Ahmed Bayjoo at Grove Garage.
Im not sure where Martin Hadland (Reyland)
Thats the only people i would recommend.
Old Dec 5, 2006 | 07:31 PM
  #52
BigErn's Avatar
BigErn
Think Stu at MSD will be best for me to get to, Blackpool is only a couple hours away. Any one got his number so I can give him a bell, or Website?
Cheers people
Old Dec 5, 2006 | 08:34 PM
  #53
rapidcossie's Avatar
rapidcossie
would have been impossible to set my car up the way it is on the road Rich..
Rollng roads are much quicker for findinf faults seeing as you can run it up as many times as needed with out risking the engine
Old Dec 6, 2006 | 06:31 PM
  #54
BigErn's Avatar
BigErn
Quick update on my situation.
Pulled the Ecu out of it today and had a look inside, under the EPROM chip and very close surrounding areas the circuit board is dull whereas the rest of the board is shiny green. Does this mean its been damp or shorting out or.....?
I have bought a new crank sensor and coolant temp sensor to fit to it too when I can bring myself to brave the cold and go outside and do them.
Old Dec 7, 2006 | 05:47 PM
  #55
BigErn's Avatar
BigErn
Since I plugged the ECU back in this morning I drove home from work and it never missed a beat. Odd?????
Old Dec 7, 2006 | 07:38 PM
  #56
BigErn's Avatar
BigErn
Just been for fuel again, done about 20 mile and it seems fine. Need it setting up now.
Thanks for your help everyone.
Old Dec 8, 2006 | 07:14 AM
  #57
CossieRich's Avatar
CossieRich
Sometimes a wiggle of the connector to the ecu is all it take to get things sorted. A slightly loose connection is all it would tkae for your described symptoms. Strange but true. See how you get on. Hope it all stays ok for you
Old Dec 8, 2006 | 01:12 PM
  #58
radiant red
cheers mate
no centre box and a scorpion style back box,gives a unique sound
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
