Decembers Fast Ford Mag....
Its Broken.....
Re: Decembers Fast Ford Mag....
Originally Posted by BillyCabrio
The free poster inside, I see the mk3 thrash made it onto one side of it........
I gotta say IMHO the cabbie's looking good
(Sorry, just biggin' myself up init!)
I'm at work.
Just set the verniers to zero and time as you normally would a zetec as a starting point.
Then if you have a dial gauge and degree wheel check the supplied open close timings against what you have.
If the cam was set up correctly in the machine when ground they should be fairly close.
Baby Cheesus
thing is tho, the cams and pulleys have holes in for a dowel to lock them both together, which i will use as i dont want what happened to that fez rally car to happen to this!
so i guess ill just loosen the 4 bolts on the pulley to get it tensioned?
ill work out im sure
Baby Cheesus
slowpoke
i dont think it is in this issue mate, i cant remember as i only had a quick flick through as we got the copies in just before i went home
the good news is that im in it
BillyCabrio
the skiving cunt is on holiday, AGAIN
cossie4i
Steve, i thought it was £37 ish?
well i dunno, cos i dont need to suscribe
your best off waiting for the banner at the top of the page, 3 issues for £3 if you suscribe through that
BillyCabrio
cossie4i
TT T38 Power
Originally Posted by fudgeass
cossie4i
Why is the above offer not given to subscribers ? Fast Ford always used to do very good subscription rates.
I know it's nothing to do with you, just a bit unhappy about it.
Steve.
borboyous
22-08-2015 11:17 AM
TommysKeeper
13
14-08-2015 08:22 PM
