cossies, when do you have full boost ?
27-11-2006, 03:27 PM
27-11-2006, 03:31 PM
saff is working!!!...atm
27-11-2006, 03:32 PM
just under 3500
a dream
how many psi ?
27-11-2006, 03:37 PM
hits 30, then holds 28 psi, feels really strong
27-11-2006, 03:43 PM
T34, in a high gear makes just under 2 bar by 3500, in first its more like 4500 though
27-11-2006, 03:48 PM
dosn't the rear housing make a difference.....it was 3300 with a .48
27-11-2006, 03:57 PM
TT T38 Power
I have a T34.55 and a ported head, mine makes full boost (1.5bar) at 3050rpm
Steve.
27-11-2006, 04:00 PM
27-11-2006, 04:07 PM
Quote:
Originally Posted by sygjim
only with the correct spec head yes.
27-11-2006, 04:09 PM
yes, it's the next step on my motor
27-11-2006, 04:16 PM
the one i have is a universal t 38 not a turbo techniques t38, the uni t38 spins up quicker
27-11-2006, 04:17 PM
Yes a smaller rear housing will generally mean a turbo reaches boost sooner.
27-11-2006, 04:19 PM
27-11-2006, 04:20 PM
my gt35 makes more boost than that at those revs
u must have a boost leak
27-11-2006, 04:23 PM
i hit full boost 2.3 bar 3500rpm on a ut t38
27-11-2006, 04:35 PM
whats the top wack for a ut t38 (bhp) i've been trying to find it on here
27-11-2006, 04:39 PM
pete mcrash
well mine at 2bar made 425 bhp with lost of room for erro made 444bhp at 2.2 bar but had a loom fault so was left ther i think good for 450bhp
27-11-2006, 04:45 PM
Re: boost
Quote:
Originally Posted by charlie luciano
Fuck knows
T35 hybrid and i just hold onto the steering wheel and point the car in the direction i want it to go
Luciano
Im just the same
27-11-2006, 05:58 PM
TT T38 full boost at 3400rpm 450 bhp 2 bar ....
27-11-2006, 06:05 PM
check your cam timing, sounds to me like your exhaust cam is a tooth out
27-11-2006, 06:07 PM
full boost by 4k on a T4.(2.5 bar)
27-11-2006, 06:21 PM
what do you mean by "Boost leak"
27-11-2006, 06:23 PM
On full boost just over 2000rpm
then mine almost gone when most of yours starts
27-11-2006, 06:28 PM
Re: boost
27-11-2006, 06:40 PM
boost leaking somewhere
boost pipes
dump valve diaphram split
penny in ex housing leaking slightly
Exhaust wheel damaged
etc etc
27-11-2006, 06:50 PM
a pic of my datalog :
27-11-2006, 06:57 PM
I have a turbo dynamics t38 and thats at full boost at 3500 ie 30 psi
27-11-2006, 07:01 PM
think this t38 boost thing is just up to a decent map....they all seem to come in the same all 3 types
27-11-2006, 07:02 PM
Tension Papillon, thats the throttle butterfly, right?
If that logger is correct you aint on full throttle as the butterfly is only open 70.92 degrees, even lower in the midrange. Should see around 83-84 degrees with a wide open throttle. Might be worth checking the sensor too.
27-11-2006, 07:22 PM
the max throttle is 80.8, it's just a part of the log
27-11-2006, 07:44 PM
Quote:
do you have a website link for the universal t38 ?
27-11-2006, 07:56 PM
the web site is a bit shit,not much info really, better off phoneing them
http://www.universal-turbos.com/head.htm
28-11-2006, 06:25 AM
Dont have access to my logs right now but I think my T34 Hybrid (0.48 from Universal Turbos) reach full boost (1,7 bar) around 3250-3350. Could double check that when I get home tonight.
28-11-2006, 07:12 AM
HAVE YOU CHECKED YOUR CAM TIMING?? do the simple stuff first
JK12
33
26-04-2021 12:09 PM
05-11-2015 08:12 PM
03-11-2015 04:08 PM
CrOwSoN15
14
03-09-2015 12:21 PM
RsS2daz
14-08-2015 05:26 AM
