cosmetic head gasket question ( reusable?)
are the 3 layer head gaskets reusable
reason i ask is ive just fitted one to my engine, but now i want to do a rebuild using my 200 block, the gasket was fitted a couple of months ago and the engine has just been sat on a stand
not even fired up
so was wondering if i could re use it or just bin it and buy a new one
thanks
not even fired up
thanks
Originally Posted by Christian and Beccy
After my recent experience, I wouldn't use a Cometic gasket atall, I reckon.
What would you recommend Christian as I need to do one on my Stage III 3 Door ?
your head and block surface has to be like glass to get a proper bite with no leaks on the cometic ones but if your heads been skimmed and you get your block decked then no problem and Ł100 rather than Ł375 for wrc,and to be honest your only going to use it once eh......
they can only be used once, they have pressed layers on them and when torqued down they are crushed to seal, if your are rebuilding your motor then the cost of a new gasket should be included for a proper job ...
had one of these on one of my saph's about 3 years ago i ran my saph for 400 miles on a new engine took the head off to replace a valve re used the gasket and it was fine for 8000 miles until it melted and i was running greys, t34, 30 psi......
but if it was to happen to me now i would use a new one for the sake of 100 quid...
ok thanks for the replies lads
i know i spelt it wrong lol, was in a rush as i had to go out
think it sbest i buy a new one then to be on safe side
and reading baout oil grommets? dont think mine had any come to think of it if there rubber thats is anyhow
head bolts im using arp stud and nut kit
but now if im going to do the build i get my 200 block machined and use my long studs
