Would someone please explain cossie ECUs please
As title really, dont understand anything about the differences in cossie ECUs and levels etc....
Would be nice to know
Level 1 was the ECU fitted to the 3 Door Sierra RS Cosworth.
Level 6 was the ECU fitted to the Sapphire 2wd Cosworth.
Level 8 was the ECU fitted to the Sapphire 4wd Cosworth.
P8 was the ECU fitted to the Escort Cosworth.
HTH mate.
HTH mate.
Is the L6 and L8 easy to go into as 3 door ?
Is much work involved , i take it its not as easy as swpping them over
Would i benefit form say a L8 ? my car has no problems so cant really see why i would
thanks
thanks
thanks
thanks
L6 would be a straight replacement(as long as it's got a correct chip for your spec)
L8 you would have to replace the tps and swap the 2 outter wires that goes to it and also get a chip to suit your spec!
Russ Payne
25-09-2015 08:29 PM
