2wd cos abs vibrating pedal
Old 24-11-2006, 02:01 PM
Matt Baxter
Back in black!
Matt Baxter's Avatar
Default 2wd cos abs vibrating pedal
right the abs light has always been on since i got the car.
so yesterday i changed all the wheel sensors but the light was still on
then this morning i was zip tying some cables up out of the way and
noticed that the green relay under glove box was not plugged in properly
plugged it in and the light went out
then just went out for a drive and at first the brakes work fine then the
pedal drops then pulses/vibrates 3/4 times and then the car stops slowly.
then the brakes dont work for a few seconds after this has happened and
the pedal is rock hard wont stop at all .
anyone know what this could be
Old 24-11-2006, 02:02 PM
Dan Cossie
Dan Cossie's Avatar
mate that is well scary get that checked out asap...anit got a clue what it is.hope ya get it sorted
Old 24-11-2006, 02:18 PM
kjc300
kjc300's Avatar
Matt,
Jaycos borrowed/bought secs' abs tester gadget maybe you could use that???
Old 24-11-2006, 02:23 PM
Matt Baxter
Back in black!
nice one thanks Kev i will send him a pm
kev are you doing the rolling road in march
Old 24-11-2006, 02:28 PM
kjc300
kjc300's Avatar
If the car is done, and if I'm here!! off on tour again!!
Old 24-11-2006, 02:34 PM
Jay,
Sponsor
Jay,'s Avatar
shit i forgot i had this need to send simon his cash to
but yeh ur welcome to use it sounds like you have a pump fault
Old 24-11-2006, 02:37 PM
RS500/364
RS500/364's Avatar
any chance i can use it ?
Old 24-11-2006, 02:42 PM
Jay,
Sponsor
Jay,'s Avatar
the joke is i still havnt got round to doin mine simon was guna pop over but never called him back as thre shonky shit heap as been locked away and forgot about
but yeh you can when matts done
Old 24-11-2006, 02:49 PM
Matt Baxter
Back in black!
thanks jay
will it be ok to pop over tomorow if so what time is good for you
Old 24-11-2006, 02:54 PM
Jay,
Sponsor
Jay,'s Avatar
about lunch good for you
Old 24-11-2006, 02:56 PM
Matt Baxter
Back in black!
yeah nice one Jay I will give you a call b4 i come over
thanks again
matt
Jay,
Sponsor
Jay,'s Avatar
Old 24-11-2006, 02:58 PM
gurnE
gurnE's Avatar
I'd just pull that relay back out
Old 24-11-2006, 02:59 PM
Jay,
Sponsor
Jay,'s Avatar
tell you what might be a better idea to
Old 24-11-2006, 03:01 PM
Matt Baxter
Back in black!
yeah done that
Old 24-11-2006, 03:38 PM
RS500/364
RS500/364's Avatar
see how close you are do you go to the surrey meet ?
can i use it there?
Old 24-11-2006, 05:46 PM
foreigneRS
Testing the future
foreigneRS's Avatar
that's obviously why the previous owner pulled the relay out rather than fix the problem
when you replaced the sensors, did you clean up the earth points for them? needs to be back to bright metal.
the fault that you describe is the most common sierra abs fault, and is usually caused by an imbalance in speed readings between front and rear sensors. usually cured by earthing the sensors properly, or in some cases replacement
Old 24-11-2006, 05:51 PM
Matt Baxter
Back in black!
do you mean where the sensors mount on the hub (with the 6mm bolt)
Old 24-11-2006, 06:04 PM
foreigneRS
Testing the future
foreigneRS's Avatar
yes, and the bolt should be in good condition
Old 25-11-2006, 09:58 AM
Matt Baxter
Back in black!
done this just now still the same .
Old 25-11-2006, 10:23 AM
Jay,
Sponsor
Jay,'s Avatar
can i use it there?
dont do the meet thing as im always workin im in basingstoke
Old 25-11-2006, 11:53 AM
foreigneRS
Testing the future
foreigneRS's Avatar
st200-tl1000r bugger. worked for me. hope you get it sorted with jay/secs on the case
Old 25-11-2006, 02:37 PM
Matt Baxter
Back in black!
thanks Jay for all your help mate
Old 25-11-2006, 02:41 PM
Jay,
Sponsor
Jay,'s Avatar
no probs matt get that short sorted and it should be fine
tankybaby66
06-02-2016 02:24 PM
muzzman1
30-09-2015 08:59 PM
Quick Reply: 2wd cos abs vibrating pedal
