Problem with the turbo, won't start!
Old 15-11-2006 | 06:40 PM
Terry Tibbs's Avatar
Terry Tibbs
Default Problem with the turbo, won't start!
Basically, it started, drove to work and then when I went to go home there was nothing, everything worked bar the engine
Battery is fully charged and it bump starts but then when you stop it won't start again.
I just got it home and when i turned it off and tried to start it, it started! but I just know it'll be my luck tomorrow that it won't start in the morning.
Any ideas? Battery is fine, alternator too, so is the starter motor lol.
Old 15-11-2006 | 06:48 PM
xr4x4rs's Avatar
xr4x4rs
check the wiring that goes to the starter make sure it hasnt been burnt
does the engine turno ver or nothing at all
if nothing then its either starter wiring or starter
droptopRST's Avatar
droptopRST
Is it turning over?
Old 15-11-2006 | 06:49 PM
droptopRST's Avatar
droptopRST
Ha beat me to it dude
Old 15-11-2006 | 06:50 PM
Terry Tibbs
When it plays up, no, it won't turn over. Wiring looks bang on. Think I'm going to stick a new starter on it at the weekend, see if that sorts it.
Old 15-11-2006 | 06:52 PM
Alvyn's Avatar
Alvyn
as above it will be the thin wire that goes to the starter motor more than likely a bad connection!
ps before you go under trying to check/take the wires off etc disconnect the battery 1st
Old 15-11-2006 | 06:56 PM
Paulo P's Avatar
Paulo P
Have you tried hitting the starter motor with something solid?
droptopRST's Avatar
droptopRST
Amen may be a dodgy wire you tried a swift bang to the starter motor lol try and free it up
Old 15-11-2006 | 06:58 PM
purple_fiesta's Avatar
purple_fiesta
No longer a ford owner ..
starter motor defo
Old 15-11-2006 | 07:07 PM
andyhardy's Avatar
andyhardy
Could be the turbo overheating the starter motor - I had this happen to me quite alot with my old FRST.
Cheers,
Andy
Old 15-11-2006 | 10:17 PM
Terry Tibbs
Well it sat for 2 days and still wouldn't work. Just tried it again 3 hours later and it works. Christ knows whats going on..
Will see if it works in the morning.
Old 15-11-2006 | 11:11 PM
xr4x4rs's Avatar
xr4x4rs
starter motor or dodgy wiring
only thing it will be
but id say more starter motor now as its tempermental
Johnsie
Ford Focus ST
08-09-2015 03:39 PM
Michael Wisbey
15-08-2015 12:57 AM
Zoggon
10-08-2015 11:39 AM
Sjieter
05-08-2015 10:47 PM
Quick Reply: Problem with the turbo, won't start!
