FAO Mike R or cossie handling/suspension guru's...
#81
Originally Posted by Azrael
I also driven one that was accident free
And most of the rally drivers over here have same opinion as me :-/
"Me: What to expect of Escort Cossie handling?
Rallydriver: Nothing much exept it swapping ends or rear stepping out at most unpredicted moments, apart from that as any other AWD. Oh and it feels huge even though it's so small"
#83
Caraholic
Escos is 20 times harder to drive fast and want's to kill you every second corner ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
But yes - I expect it should handle better now. If not I'll have to call you for rear beam. Geometry is currently contrary to what you like 0'07 toe out on the rear.
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
#84
Must be all down to the set-up, as mine handles lovely, as you can testify from the passenger lap of the Ring
You yourself said you weren't at the car's limit because of the driveshaft ;P
But seriously yours is surely great I'm talking about standard(ish) car. It's the same with my "company car". It doesn't even feel similarly to standard one. Standard Impreza GC8 is rubbish on tarmac compared to Cossie - no turn-in whatsoever.
Anyway - we'll see this year, maybe it's just down to my shonky driving skills
#85
This article might interest some people as regards the handling of the 3-door especially the bits on the penultimate page. You might find it fun to look at anyway as it is a comparison of the 3-dr vs the E30 M3 ( performance Car was the forerunner of "EVO" mag )
Here it is http://s20.photobucket.com/albums/b2...shrops/3-door/
If you go on a few more years it is also interesting to see all the work that went on the 4-dr changes as regards the suspension and why they were made and what SVE were trying to achieve. When the later car was rematched against the BMW it was a different story
#86
Originally Posted by bud-weis
On the new cossie i have a bit of a problem which i'd like to solve......
basically when driving on any uneven road (which is about 90% of UK roads!) the car tramlines really badly and pulls you into the grooves/bumps in the road....it's very noticeable on the motorway in the left lane where lorries have left a groove.
Now i've tried different tyres and it's not that,my next port of call will be checking the wheel alignment/geometry i think,and possibly replace the lower arms,maybe with adjustable jobbies from Zoo,
what i want to know is what is the usual cause of this? i'd like to fix it asap,because frankly it's verging on dangerous if going at any speed....and i'm not sure if the quaiffe diff exaggerates it a bit too
LOVE cossies
LOVE cossies
im glad i haven't had any of this since it was set properly yrs ago
marco
#87
Football Cwazy
You CAN'T just say that
it has improved massively form when i first had it.....i've changed all 4 tyres and the front is set to toe-out slightly (i'm gonna play with these settings more i reckon)
#88
i think the main problem, is that the car designed with 15" wheels originaly
once you go bigger wheels you have to change the settings to suit ,
putting the adjustable tca on is a big help
marco
#89
Football Cwazy
yeah,i think i'm gonna order a set actually,what's a good setting to have then,without causig massively premature tyre wear or anything like that?
#91
#92
Football Cwazy
yeap,Jim's old car,and the current TCA's aren't adjustable i don't think (although typing this i'm starting to think i'd better double check
#93
try what mike has said first ....fair play to him for giving you the advice
it's not going to cost you a great deal
marco
#94
#95
Football Cwazy
#96
martin
personally i dont like getting involved with geometry settings because alot of peeps have got nothing on there cars to adjust settings and how far do people go on a road car with ATCS's/roes jointed trailing arms/castor ect ect theres not that many that do
my car adjustable is the sence tow in/out rear / camber
front castor is preset 10mm more forward than standard /adjust tca's i can mess about with it to suit
i have no issues with turning in or tramlining only because it's adjustable and has been set up properly not too much for track or road
people are on about bumpsteer once the beam is solid mounted and you have rose jointed rear arms and rose jointed rear suspesion(top/bottom)most of the bumpsteer is removed because nothing can move to an extent rubber moves metal doesn't simple
everything on my car is metal to metal but like i said how far do you go on a road car
i am well happy with my car i got got the right balanace between both worlds
marco
marco
#98
marco polo no problems with allt hose metal-to-metal joints in road usage? Corrosion? Wear?
been on the car good few yrs no probs so far however the will need replacing at some point but so do rubbers
my beam is also solid mounted to stop movement
it was best thing i ever done i will never ever go back to polybushes or rubbers on the chaissis
theres 3 things i kept on my car which was uprated then taken off,
was the rear diff mount /gearbox mount and the front engine mounts
all these i put back to standard as they were transfering noise and vibration
on a 4wd it's best to keep the uprated engine mounts
marco
#100
Football Cwazy
thanks for the info Marco
personally i'm not a fan of polybushes AT ALL,every car i have had them on (including my current one) has not felt as good as a car with new standard parts (or solid joints)
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
#102
marco polo I have vibratechnics engine and gearbox mounts and they are fine to me.
yes but they are needed on 4wd cool is all your back end metal to metal too ?
if so do you find more vibration through them
Apart from that I nly have adjustale TCA's with metal to metal on the attachment to front sub-frame. The rest is polybushes (which I like just fine on other cars I know, e.g. Imprezas).
#104
let me give you an honest opinion here your car is a 4wd and you have poly bushes on the back of your car you also have got rubbers on your trailing arms , you have also got rubbers on your suspension
now what is stoping your beam/ suspension/ trailing arms/suspension from moveing ????
how cam i say this ...but when you have got metal to metal and proper suspension ... it totaly transforms the car on the way it handles really and truly does once it's set up
you cant beat metal to metal simple as theres no substitute
there is nothing wrong with metal to metal on the road the only thing you will notice is more vibration though the car "as you have got uprated gearbox mount and engine mounts "
i dont get vibration at all because my car is rwd and has the standard diff mount/gearbox mount/and engine mounts and my car feels no differance to a car with polys on the road infact it's a 10x better
dont belive everything you hear about rose joints alot people comment about them who haven't even experianced them they are great simple as that
and like i said i wouldn't go back to rubbers on the chassis ever again
you can ask anyone that has driven my car what's it's like on the road and like i said it's no worse than polys
i dont know what the roads are like in poland so i cant comment but honestly it does most defo eliminate alot of the bumpsteer once you have all the metal to metal back end and you know one good thing when you have this it makes the suspension do the work not the rubbers
i have even asked Mike to drive the car to see what he thinks
I know your is 4wd and mine is 2wd they are more or less the same car
I am no expert on this subject and i'm am only going from experiance what works and what i have tried and spent lot of money to sort it and then give it all away free
marco
#105
Football Cwazy
where's best to get them from then people
#106
Caraholic
Having everything rose jointed, will not necessarily remove bump-steer
, this is all about how the geometry is set, so that when the suspension travels up and down (the change from static ride height, to full droop (wheels at the longest extension with car off ground) to full compression (suspension compressed until bump stops), the toe remains where it has been set at it's static level.
A car with "bump steer" means that as the suspension travels up and down, the toe geometry changes depending on what height the wheel is in in its travel
#107
Why not try Karl at Zoo? He used to do 2 types - one with replaceable balljoints.
He's very good on chassis stuff
#108
Hi Mike
i understand all that but the point i'm making !!! rose jointing every does help a great deal on the back end and when you have got good rose jointed proper suspension does eliminate alot of the bump steer everything i have mesioned above in previous posts
when you have got this kind of stuff on your car the bump steer IS NOT an issue to cause the car to handle any worse it's not even a talking point
thats what i am saying
bump steer however on a standard cossie with standard stuff on it bump steer is herendouse .. the back steers the front ......lol..pmsl
you can even speak to Harvy or anyone that raced grp a cossies they will tell you the same thing you get to a point where isn't an issue when you have got the stuff on the car it's simple as that
and if there is bump steer it's not enough to upset the handling or the way the cars drives at speed
I spoke to Ray who worked on the wrc/grp a programme i had the converstion with him ages ago and thats the info he gave me
like i said i am no expert on the subject
thats why i did say how far do you go on a road car
marco
#109
Hi Azrael
I have whole set of polybushes so no rubber
Well I can see only way is to try calling Mike when I have the money to spend
#110
The new generation of rose joints are teflon linered which lets them last a lot longer because it's harder for water and trash to get inside of them. There is a compnay in the states called QA1 they have everything you need.
#111
marco
marco
#112
Football Cwazy
Ok....thought i'd resurrect this thread as there are a lot of good opinions on it,and good advice!!!
Anyhoo.....I now have Adjustable TCA's,and will try Mike's recommended settings,i'm expecting big things this weekend
Since i first started this post i have noticed improvement after changing all 4 tyres,obviously the ones i had before weren't quite suited to my car.
I'm hoping the mix of 3 door hubs,and adjustable TCA's mixed with the Koni/Ahmed spring and damper combo will make the car feel very very good.It already has a very responsive,sharp feel to it now
The rear end however may have to wait a while,i'll see how it feels first and decide what i want to do
#113
Caraholic
The rear end however may have to wait a while,i'll see how it feels first and decide what i want to do![Top](https://passionford.com/forum/images/smilies/smile011.gif)
#114
Football Cwazy
Yes,your probably right,but in all honesty i haven't pushed it hard enough on the road to feel it understeer at all
i'll give it some beans at the weekend and see how i like it
#120
Caraholic
Originally Posted by MAD YUM
£2,600 for two way adjustable with remote gas reservoir
. Once I have recovered from the engine cost, I'm thinking about these
Mmmmmmm so looks like we will be seing another version very soon then
