lowering transit vans... and alloys...
Its Broken.....
im gonna be buying a transit van soon, a swb single wheel one. basically, i wanna fit either 17in 4 stud or 24v wheels. can i swap the front hubs for sierra/ granada ones? rear axle is there a direct swap ie 3.0 capri???
cheers!
cheers!
If its a 6 stud one i think yout buggered
I knew someone that Put Transit Hubs on a P100 Pick up so must be able to do it on the older ones
Originally Posted by JTECHSAFF
cant you raise the stub axles on the back to lower them?
make some plates up on the end of the axle so the stub can be bolted up higher, ive done this loads of times on vw stuff like my caddy sport i lowered 120mm
You can buy the quad headlamps off the shelf for a transit 1991-2000. this is mine.
As for the stub axle idea that wont work as the rear axle is the drive axle. I'm running 17inch alloys on mine on adaptors and to lower the rear you need to get the springs decambered.
You'll need hub adapters, try on here http://fordtransit.org/forum/ , somone was making then, not sure if they got em finished or not yet?
SMILER258
28-09-2015 09:04 AM
