Mapping question about S8 ECU
Hi, im currently gathering all the parts for my N/A Zetec based track car, i have a SECS S8 ecu doing nothing and was wondering if it can be used for N/A using TPS V RPM? I can select the engine trigger type to Ford EDIS 4, and select no map sensor fitted but in the main Fuel and Ignition tables it still shows MAP v RPM
Am i missing something silly here
or is it not possible to go N/A on this ECU
Cheers Bri.
Cheers Bri.
Ah....... Thought it might be something simple, it threw me when i seen the option to disable MAP sensor and thought it would change the tables automatically, cheers Chip
What do you think would work best out of these:
STD inlet, T/B
Custom plenum, Cos T/B
Custom plenum, multiple Zetec T/B's (1 per cyl)
No plenum, multiple Zetec T/B's
Will have to make a remote ISCV for the multiple T/B idea, just toying with a few idea's at the moment
Bri.
STD inlet, T/B
Bri.
a couple of years ago Simon stuck a S8 on my old mk6 escort with motorbike throttle bodies
first ever NA car t have one too lol
so yes - it can be done, prolly best off speaking to simon tho
Your ecu can run N/A already.
Its not obvious how to do this and my implementation isnt ideal but it does work.
Select MAP sensor type as NOT FITTED.
Then rescale the IGNITION map BOOST scale to 0 to 10.0 psi
in divisions that suit your mapping requirements.
Then 0 to 10.0 psi represents 0 to 100% throttle position.
This will be echoed in the fuel map too.
Obviously then all map related settings become irrelivant.
Alternativly....
It is possible to use MAP on N/A but you will need to link all throttles
together with a pipe to the sesnor IF using throttle bodies.
You will also need to run a TPS too.
Alternativly....
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
