Audi A3 wont start
Old 02-11-2006, 02:22 PM
ballin
ballin's Avatar
Default Audi A3 wont start
Got a problem with our Audi A3, its a 1998 model S-reg, thought someone on here may have an idea
Car was sat for about 2 months with no use, and obviously came back to find a dead battery.
Tried jumping it but it just cranks over and doesn't fire.
Have checked for spark, its sparking.
Have renewed the petrol with fresh stuff.
Now, the problem is it isnt fueling. When you turn the ignition on the fuel pump doesnt prime, and when you try to crank it no fuel comes through.
Have tested the circuit and there is no power going to the fuel pump fuse, so the problem lays between the battery and the fuse.
In between these is the relay? I've replaced that to no avail.
If you give a live feed to the fuse then the car starts and idle's happily, so the fuel pump works!
The problem is definately before the fuse but not the relay, what can it be?
Any other fuel cuts on there?
Old 02-11-2006, 02:31 PM
Dan Cossie
Dan Cossie's Avatar
call an audi dealer mate and see if they can say over the phone if not call AA and say it has broke down, they will stick a diagnostic pc on it and may tell you wats wrong
Old 02-11-2006, 02:41 PM
ballin
ballin's Avatar
had the aa out twice now, first time they said low oil ( I wasn't there at the time) and the second time they tested it all and said must be the fuel pump relay.
and now here i am, it aint the relay
may get em out again tomorrow but will try audi
Old 02-11-2006, 02:49 PM
ballin
ballin's Avatar
shit!
audi confirmed my worst fears, gonna have to chase the connection back from the relay, all the way to the battery!
absolute cnut of a job
Old 02-11-2006, 02:58 PM
jr
jr's Avatar
Just had a word with out master tech here mate, he said its difficult to say, but could relate to the ignition switch
he said try moving the key round in it, as usally where then go, they dont spring back and the normal turning movement in the barrel from 1-2-3 feels strange
Old 02-11-2006, 03:00 PM
jr
jr's Avatar
Gonna be difficult mate, but might be worth sticking it on diagnostic to see if it brings up anything, ive got the software for it but not that close
Old 02-11-2006, 03:03 PM
ballin
ballin's Avatar
thanks for that mate, as far as i can remember the barrel felt normal, but i will give it a go!
would what he suggests still be true bearing in mind it works when giving a live feed to the fuel pump fuse?
Guess I'll have a small play tomorrow then get the aa out again! although i guess now its this complicated they wouldnt be able to suggest much, other than a tow to audi?
Old 02-11-2006, 03:11 PM
jr
jr's Avatar
true, ive not got the wiring diagrams for it infront of me and evreything
the other suggestion is that the feed from the control unit that powers the relay is at fault, or its not earthing
Old 02-11-2006, 03:13 PM
wayneclayden
590 BHP/Ton
wayneclayden's Avatar
might be worth checking the ECU connections .. as far as I remember there is a live feed from the ECU to the fuel pump relay.....
Old 02-11-2006, 03:15 PM
jr
jr's Avatar
mr pro alloy is correct, i can fax you the wiring diagram if it helps ballin
Old 02-11-2006, 03:23 PM
ballin
ballin's Avatar
Hmmmm I reckon you could be onto a winner there! Just hope the ECU is okay
jr if you could fax it mate i would be so grateful
01256 742480
Cheers mucho
Old 02-11-2006, 03:27 PM
jr
jr's Avatar
Sent
Old 02-11-2006, 03:30 PM
ballin
ballin's Avatar
got it mate thanks a lot i really appreciate it
Old 02-11-2006, 03:31 PM
ballin
ballin's Avatar
page 2 you sent, is that the main ecu or does it have a seperate fuel ecu? (and if so do you know where it is?)
Old 02-11-2006, 03:32 PM
jr
jr's Avatar
its ok mate, if they make sense then thats as they were beeing explianed to me and i was a bit
Old 02-11-2006, 03:33 PM
jr
jr's Avatar
thats the ECU (main one) saying that what engine is this A3 mate ?
Old 02-11-2006, 03:35 PM
Alvyn
Alvyn's Avatar
JUMP starting some Audis with another vehicle can blow something in the ecu but jumping with a jump/booster pack is ok!
Old 02-11-2006, 03:37 PM
ballin
ballin's Avatar
its the 1.6
diagrams take a little studying lol, im no leccy really but its better than nothing
Alvyn, so i found out post jumping it hope the ecu isnt fried
Old 02-11-2006, 03:38 PM
jr
jr's Avatar
were soon find out, if you have issues i'll come and plug my ECU into it before yoy spend ŁŁŁ
Old 02-11-2006, 03:39 PM
Alvyn
Alvyn's Avatar
that's a fine offer there
Old 02-11-2006, 03:40 PM
jr
jr's Avatar
that makes no sense i meant i'll plug the laptop into the ECU
Old 02-11-2006, 03:41 PM
ballin
ballin's Avatar
that would be good mate thanks for all your help!
having a little trouble reading the diagram for the ecu, is J17 (fuel pump relay) the one above the black box at the top of the diagram?
if so what is it? how can i test it?
i assume its a pin out? should it be earthed or live when ign is on? or dont it say?
Nath
Nath's Avatar
Rich, Im going to put that number on some swinging & dogging websites
Old 02-11-2006, 03:44 PM
ballin
ballin's Avatar
Nath, be my guest, its my work one
Old 02-11-2006, 03:45 PM
jr
jr's Avatar
J17 23/87 is the one above the black box, sorry thats the highlighting over it
its the fuel pump replay, that should be live when the ignition is cranking
pm me your reg and i'll make sure these are 100%
Old 02-11-2006, 03:55 PM
ballin
ballin's Avatar
ygpm !
just to clarify as the image is a little fuzzy, out of the ECU on pin 4 is it (?) there is a wire running to the fuel pump relay, and this provides the power to the relay?
so the power to the relay comes from the ecu? cant see what colour the wire is, is it on there?
Old 02-11-2006, 04:02 PM
jr
jr's Avatar
yes as far as i can work out, its ecu powerd
it says purple/white, but i'll check that with your details, as i guessed it was a 20v turbo
Old 02-11-2006, 04:09 PM
ballin
ballin's Avatar
ah okay, unforunately not, boring 1.6 ! It's the early 1998 one as well apparantly, WX chassis number or something? had this little problem yesterday trying to get the right relay, turns out they changed late 98 or something, and mines the earlier.
jr
jr's Avatar
its all the same on a 1.6, still gets a feed for the ignition switch, and ecu
Old 02-11-2006, 04:10 PM
jr
jr's Avatar
thats down to shit part advisors, its simple really (he says hoping you didnt buy it from here)
Old 02-11-2006, 04:12 PM
ballin
ballin's Avatar
lol no was camberley, ok thats cool then.
so i need to check if the purple/white wire from the ecu is live when cranking.
if it is then it must be the relay board or something
Old 02-11-2006, 04:14 PM
jr
jr's Avatar
yeah you need to find out if the pin out form the fule pump relay is live when cranking
Old 02-11-2006, 04:15 PM
ballin
ballin's Avatar
gonna be fun, can hardly get in there as it is, let alone trace the wires
sorry, is it purple or white, or purple/white?
Just had a quick look at the relay, I've got pins 85,86,87,30
looking at the diagram, pin 87 should be live yeah?
(sorry for all the qs)
Old 02-11-2006, 04:18 PM
jr
jr's Avatar
its lists it as purple/white
and one of those for 1001 posts
Old 02-11-2006, 04:20 PM
ballin
ballin's Avatar
slight edit above!
be 2000 when ive finished
Old 02-11-2006, 04:26 PM
ballin
ballin's Avatar
85 and 86 should be permanent live? and 30 and 87 live when cranking?
have i got that right?
Old 02-11-2006, 04:30 PM
jr
jr's Avatar
as far as im aware mate yes
Old 02-11-2006, 04:35 PM
ballin
ballin's Avatar
thanks so much for ya help mate, i owe ya
will see what happens tomorrow, see what else i can break
Old 02-11-2006, 04:45 PM
*Bri.4.b.Cos*
*Bri.4.b.Cos*'s Avatar
Just out of curiosity have you tried the inertia switch to see if its popped up??
Bri.
Old 02-11-2006, 04:47 PM
ballin
ballin's Avatar
wheres that mate
Quick Reply: Audi A3 wont start
