Can i make my Fuel Gauge Lie ????????
I need to make my fuel guage on my Diesel escort Van read empty even though its nearly full. I cant say why but does anyone know how i could do that. If you turn the ignition off the needle stays where it was . I need to trick it somehow. Any ideas
mine lies to me all the time, and when i turn my lights on it lies even further, strange things these Ford Fuel Gauges
try disconnecting the sender unit, if its easily accesible (sp) or removing the fuse that operates the dash cluster?
just random idea's here mate i dont really know
I dont want to syphon the tank. I filled it up at the weekend before i found out it needs to be empty by this weekend. If only i could have been one of my old cars i could have driven for half an hour and it would be empty but i,d have to drive this to Scotland and back to empty it
Mine lies to me BIG time!!
When it's just me it's always about 1/4 to 1/2 as soon as faye gets in it goes to the red
My car must hate me, it knows i'll get my ass whooped one day!
She tells me off EVERY time
Originally Posted by bud-weis
i think if you have a p;ay with the wires on the sender unit,you should get it to drop,usually just earthing it out
Originally Posted by Thrush
You say it needs to be empty by the weekend - fooking the guage won't make it empty will it? just make it nearly full with a fooked guage
Originally Posted by PROMETHEUS
If you ground the signal wire it will either drop or show full. If it goes full scale get a high value resistor and ground it thru this, try a 1k ohm.
Originally Posted by dave green
If you earth the wire it will show full.
I think if you disconect it from the gauge end it should fall
Dave
Dave
It won't fall sorry, just changed the clocks in my escort diesel van. You are going to have to simulate an empty tank, which requires a signal of some kind.
push it up with a cable tie
i did ythat
i filled with 20 quid
this is what it read
its now on the first line
well was
its ether that or change to digital dials
i did ythat
well was
duh, a resistor works the same either way round, a fuel sender is a variable resistor.
disconnet the sender wires, take the clockes out and push the needle down to the empty mark, refit dials.
if you disconnet wires the needle will stay where it is.
come tell us why it need to show empty when its not, you having welding done next to the tank or something
or is your boss gunna pay you some petrol money to go somewhere or something
hold up, just had a thought, ya gunna take some bird out and make out you run out of juice down some dark lane and ya best jump in the back to keep warm
Originally Posted by Nick_RSIFEZ
i'm guessing to claim back for fuel expenses for some sort of job that didn't really take as much fuel as he's claiming for
what do i win??
what do i win??
Originally Posted by AndyBlackFRST
Surely removing the fuse for the fuel pumpwill show as empty ?
Besides they prob a mechanical pump on a Escy Diesel.
Dont worry. I haven,t got to do it now, after all that. Thanks for the suggestions though anyway
Sheepdisease
30-08-2015 09:11 PM
