help needed escort si idle
my escort 1.8 si daily runner around has devloped a problem after starting it idles fine until you blip the revs or pull up to a junction and the revs drop it stalls . and some times the revs rise and fall on idle . it seems to be getting worse as the cold draws in any ideas ??
thaks Paul
thaks Paul
had a new set of leads and plugs not long ago aswell as new air filter and the maf did not look cloged then . thinking about it now it does hesatate sometimes under acceleration
Don't buy a new one until you have tried cleaning the old one. Check the electrical conection too.
You will not see that your MAF is clogged, all it takes is a bit of oil of a chavy induction kit on the 'hot wire' to make it go wrong. Spray carb cleaner into the MAF to clean it, not with the engine running!
i'll try cleaning them first . and the car is totally standard so no
Originally Posted by Wardy257
chavy induction kit
muz
16-08-2015 12:57 PM
Zoggon
10-08-2015 10:39 AM
