Making a YB rev
Old Oct 25, 2006 | 10:59 PM
scruffythefirst's Avatar
scruffythefirst
Default Making a YB rev
Whats required to take a healthy but standard yb to 7.5k, 8k or 8.5k rpm (management and turbo aside)
Old Oct 25, 2006 | 11:06 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Nothing, it's all there
Old Oct 25, 2006 | 11:14 PM
scruffythefirst
Even on hydraulic lifters and non pocketed pistons?
Old Oct 25, 2006 | 11:31 PM
NMS Badboy^NUTTER^
Yes, mine revs to 8,300.
Sorry , forget to say you need different valve springs, but thats all
Old Oct 26, 2006 | 07:23 AM
Sticky.'s Avatar
Sticky.
Default Re: Making a YB rev
Press the right pedal usually makes it rev to 8k
Old Oct 26, 2006 | 09:51 AM
JjCoDeX75's Avatar
JjCoDeX75
Interesting - which valve springs - esky?
JJ
Old Oct 26, 2006 | 09:53 AM
Garage19's Avatar
Garage19
A decent amount of ignition advance dialled back in after peak torque usually helps.
Old Oct 26, 2006 | 09:59 AM
8500RPM is abit much for a YB std (destroying engine)....8300rpm is borderline..i have 8200rpm limit using isky valve springs.
Old Oct 26, 2006 | 10:04 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The standard lifters will pump all their oil out and the springs go coil bound if held above 8000rpm for even a short period of time .
My new engine (and the one on the T66 thread), which will rev to 8500, will be on solid lifters and Cosworth DFV (old F1 spec) valve springs .
Old Oct 26, 2006 | 10:21 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Fuck revving one to that. No need really in turbo form, even at well over 500bhp.
And to make it give useful power that high up at well under 500bhp would mean losing you out loads of low down power, so the powerband size dont change really, making it totally pointless
Old Oct 26, 2006 | 10:37 AM
Garage19's Avatar
Garage19
Bosh man,
On a sligtly different subject....
You sig says you have a 600bhp saf?
Did it make 600bhp on the dot?
Old Oct 26, 2006 | 10:42 AM
Originally Posted by Garage19
Bosh man,
Thats a predicated figure at 2.5 bar, but he has only run it at 1.7 bar so far.
Old Oct 26, 2006 | 10:46 AM
Mike, Rods held quite a few seconds over 8000rpm on standard lifters, as it hit the 8300 limiter (210mph) when he was doing a run and was then held at nearly 8200 till he got to the line (206mph)
Chip is correct estimated....no reason why it wont be close on max boost.
Old Oct 26, 2006 | 10:52 AM
Mike Rainbird
Caraholic
They don't sound very nice afterwards and it usually takes a few minutes for them to refill with oil . I am personally going for solid lifters, to make it safe.
Steve,
I'm hoping to fill in what I expect to loose response wise with having to run these cams, with the Mountune roller-barrel inlet, and if necessary, 3.9 gearing to sharpen it up further. That way, I "hope" to get thebest of both worlds (obviously the slight increase in capacity will help) .
Old Oct 26, 2006 | 11:01 AM
Mike wont it pain you that i will piss past you in MAD car on any straight?
Garage19's Avatar
Garage19
Bosh man,
So what is to say somthing won't break at 2 bar, his mapping is will allow 600bhp at 2.5 bar, his cooling/airflow is capable of 600bhp at 2.5 bar?
What did it make at 1.7 bar?
Boschman, I think you change your sig to "a predicted / guessed 600bhp saff"
Old Oct 26, 2006 | 11:06 AM
Steve,
I dont like the thought of them over 8K myself either, ive gone for solids for my engine (LET not YB but extremely similar) was just saying its not quite as dramatic a sudden death as some people may have read your post as meaning.
Old Oct 26, 2006 | 11:16 AM
Garage19......its a MAD built engine for that BHP and all cooling etc is taken care of..it will run 2.5 bar no probs...although i may not go that high..probably stick at 2bar.
My sig is exactly what it would be at 2.5bar...regardless of wether it will break...its all there its wether i am man enuff to run it at that!
No different from saying i got 700bhp DYNO figure..incar you aint..same as rolling road figures..my ASS dyno tells me what power..remember i am part NMS aswell
Old Oct 26, 2006 | 11:22 AM
AlexF's Avatar
AlexF
Who needs solider lifters?
Arn't all rockers solid anyway
I can make mine rev to 9k on std bottom end.
Alex
Old Oct 26, 2006 | 11:23 AM
AssDyno ™
Copyright of Dingy
Old Oct 26, 2006 | 11:25 AM
Alex
No you cant
It wont be standard bottom end if it has:
S rods (and isnt an S)
A centre mains strap
A balanced crank
A hotter cam (well its in the bottom end, LOL)
Garage19's Avatar
Garage19
So you are not even going to run it at 2.5 bar??? how can it be a 600 bhp engine then.
@ 2.5bar regardless of wheter it will break??
That means i can say the stock 2ltr zetec i have in the corner of my shed is a 400 bhp engine because i'm sure it would make that if i rammed 2.5bar down its neck..... regardless of if it will break
So what did your engine make at 1.7 bar? Why don't you stick that figure in your sig until proven your figures!
Old Oct 26, 2006 | 11:28 AM
...the diffrence is mine is built to take it and everything is in place..its only a turn of my boost controller away
As for my sig..its my sig and i can say what i like..i may put it to 700bhp with race fuel.
Old Oct 26, 2006 | 11:34 AM
R5FORD's Avatar
R5FORD
pmsl
Old Oct 26, 2006 | 11:36 AM
Mike Rainbird
Caraholic
Phil,
Lets say for arguement's sake that you DO make 600bhp, I still think Peggy would waste you in the current format, as you have done NOTHING to ensure traction .
Old Oct 26, 2006 | 11:38 AM
...Mike i have your shims and 235's and caravan assistors
Must admit on 1.7bar 2nd gear is lairy it starts to drift
Old Oct 26, 2006 | 11:39 AM
Mike, you call your car "peggy", he already has you beat in everyway that matters
Old Oct 26, 2006 | 11:41 AM
Mike Rainbird
Caraholic
Jen calls it that and it seems to have stuck .
Old Oct 26, 2006 | 11:42 AM
Garage19's Avatar
Garage19
..... and change your name to billy bullshit!
Can't stand people who make up their bhp figures without ever testing them. Maybe you should go and work for TVR!
Old Oct 26, 2006 | 11:43 AM
WD Pro's Avatar
WD Pro
Yes - I heard you leave last night
Old Oct 26, 2006 | 11:44 AM
R5FORD's Avatar
R5FORD
oh what a poor excuse, blaming your wife ( i think) for calling your car peggy
Peggy is named after me...as before i shagged Jen she said what a large tent peg you have...and said i will name Mikes car peggy and he will never know the real reason.
Old Oct 26, 2006 | 11:46 AM
R5FORD's Avatar
R5FORD
such a clown phil ... but funny
Old Oct 26, 2006 | 11:48 AM
I think when she pointed over at you and your car and said "there goes peggy now, capable of doing it in 11 seconds" it wasnt the car she was pointing at..............
Old Oct 26, 2006 | 11:49 AM
Kev.H's Avatar
Kev.H
Question for Mike Assnerd are you ditching the T4 and going Turbonetics
Old Oct 26, 2006 | 11:50 AM
R5FORD's Avatar
R5FORD
oo a fast one from chip tthere
Old Oct 26, 2006 | 11:52 AM
Bugger, phone rang as i was replying and i got beaten to it by Phil
Thats the same way he ended up being Katies father
You snooze you lose in this game
Old Oct 26, 2006 | 11:53 AM
Cant be Mike as pon reckons he is capable of doin it in the 9's..i guess it depends who he is shagging...a female will take longer
Old Oct 26, 2006 | 11:54 AM
I think the extra 2 seconds is cause he has to whack it off a bit first to get it up if there is a girl about
