CO <=> Lambda ??
Old Oct 23, 2006 | 05:34 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default CO <=> Lambda ??
What is the relation between CO and Lambda that is measured during the MoT? The richer (higher) CO reading the lower the Lambda value?
Or is there more to the lambda value?
The reason I ask is I can do a pre test on a CO machine that hasn't got a Lambda reading, so if there is direct relation between the two of them I know when my CO reading is good the lambda also will be good.
Old Oct 23, 2006 | 05:37 PM
Yes there is a link
Lower the CO the leaner the lambda reading will be.
Old Oct 23, 2006 | 05:41 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
So when the CO machine is reading almost 0,00 % at idle this means the Lambda is almost 1?
Old Oct 23, 2006 | 05:50 PM
scottbrown's Avatar
scottbrown
it means that you have run outta fuel.
0% is low aint it on CO reading?
Old Oct 23, 2006 | 06:05 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Yes, that's what I mean, a reading of 0,00 % CO.
Equals that lambda=1?
Old Oct 23, 2006 | 06:15 PM
Rick's Avatar
Rick
very close to, yes, but will never be 0%. It's related as chip says, but there is no absoloute constant of proportionality.
Old Oct 23, 2006 | 07:38 PM
the original's Avatar
the original
Nothing is that simple
Lambda is a calculated value, calculated from co, c02 02 (possibly hc i can't remember) and various constants
in the uk we use the brettschneider method of calculation, which if you really wanted to see you could google
in the equation low Co helps get a good lambda value, but high Co2 is very important as is low oxygen content
so various conditions affect the lambda readings, including burn quality
and lambda can vary from the engine to the exhaust tip, for example a leak will raise O2 content and therefore increase the lambda shown on a gas analyser
when you see a car being MoT'd and Co=0, and lambda = 1.00 it will have a cat fitted, which requires lambda=1.00 ideally, and the CO content is removed by the cat even though it's present at the exhaust ports
i could go on, as it's my job every day but i don't want to be boring
but yes ,you could say generally low idle Co will give a better idle lambda reading
Old Oct 23, 2006 | 07:44 PM
the original
...but if you go too weak the Co will go even lower
Si B
Sep 12, 2015 06:49 AM
mint_s2
Sep 2, 2015 08:58 AM
Dahl88
Aug 22, 2015 08:16 PM
RsS2daz
Aug 14, 2015 05:26 AM
flashpoint
11
Jan 18, 2005 04:11 PM
