Mapping concepts
Old Oct 23, 2006 | 01:56 PM
CJBear's Avatar
CJBear
Default Mapping concepts
Reading many threads on debating likes of turbo sizes ecu hardware software this then that all means shit to me For argument sake going to refer to a normally aspirated engine in standard trim. All i understand from reading from here the whole point to mapping is to make more power aight but how? How would you even begin mappng a standard car after u hook up everything like??
Old Oct 23, 2006 | 01:58 PM
Default Re: Mapping concepts
"Mapping" is just making sure the ignition is advanced as far as is safe, and the fuelling is doing what you want (so for an N/A car about 12:1 flat out)
Old Oct 23, 2006 | 02:06 PM
CJBear's Avatar
CJBear
I seen various screen prints of what looks like series of tables and a green mountain next to it? I guess this is where you would change the ignition and fuel figures but what do all the figures means? Fair enough 12:1 is what a non-turbo car should be, but what about everywhere else like normal driving how does that translate?
Old Oct 23, 2006 | 02:08 PM
_DAN_'s Avatar
_DAN_
Yoon
https://passionford.com/forum/viewto...hlight=mapping
Old Oct 23, 2006 | 02:10 PM
The best thing you could do is read Stu's live mapping tutorial, but essentially the grid next to the graph is like an excel sheet, up one side is RPM and up the other is either Boost or Throttle position
The values in the grid tell the ECU how much fuel to put in for any set of cricumstances.
So at 6000rpm and 90% throttle, it looks up the values for that, and opens the injector for the amount of time it says in the map.
Get your head round that concept first, and then we can talk some more about other factors that also enter into it that arent clear from that map.
Stu's topic is here:
https://passionford.com/forum/viewtopic.php?t=93911
Old Oct 23, 2006 | 02:50 PM
CJBear's Avatar
CJBear
Been reading that thread but sort of lost me, just want to learn how you guys go about mapping a road car. I do not care at this stage about ecus hardware software firstly like to get my head around concepts but what are they
Old Oct 23, 2006 | 02:56 PM
CLICK HERE FOR FULL SIZE: http://i7.photobucket.com/albums/y25...icp-rp-005.png
Thats an ignition map.
The ecu looks at sensors on the engine to determine your current RPM and Boost.
It then looks up on that table to find the appropriate value, (if its in between two or 4 cells it takes an average basically)
So at 1 bar of boost (2000mpa) and 5000rpm, it would take the values of 18.25(1751mpa) and 14.25(225amap) and come back with 16.25
So that would be your base timing in degrees
Old Oct 23, 2006 | 03:14 PM
CJBear's Avatar
CJBear
Right so how do you get those figures to start off with?
Old Oct 23, 2006 | 03:16 PM
CJBear's Avatar
CJBear
Right so how do you get those figures in the tables to start off with? is a base map basically all the tables filled in with default numbers or one which is designed to run a standard car 'out the box'
Old Oct 23, 2006 | 03:18 PM
When you buy an ECU, its blank.
You either guess at some figures to get it running, or you beg/borrow/steal them from someone else with the same ecu
Thats just to get you "in the right ballpark" you then do the process of "mapping" to refine them to more suitable values for your car than for audi 20vt or whatever you just stole the numbers for!
Old Oct 23, 2006 | 03:30 PM
CJBear's Avatar
CJBear
ooo so its a crafty job then
Looking a your picture you got RPM against Map sites (whats map sites?) sticking with non-turbos how would this work? guess you would use RPM against throttle position or from air flow sensor or manifold pressure (map)?
Old Oct 23, 2006 | 03:34 PM
Yes any of those 3 options is fine for an N/A motor.
Airflow meter being the most common on production cars
Old Oct 24, 2006 | 12:55 PM
CJBear's Avatar
CJBear
what sort areas would you look at getting a car to idle?
Old Oct 24, 2006 | 12:58 PM
To get a car to idle you only need to look at the no load values at the low rpm end of the scale.
but most ECU's have seperate idle strategy's as well not on those maps, on the L8 from RP Labs for example you have a curve of required idle speed versus temp, and you have adjustments for timing based on distance from idle etc.
There isnt just a single box that you enter a value in to get the car to idle, its more complicated than that.
Old Oct 24, 2006 | 01:03 PM
Is there something specific you are after knowing, or just "in general"
Ie, Have you just bought a mappable ECU or something?
Old Oct 24, 2006 | 02:08 PM
CJBear's Avatar
CJBear
Just in general really the typical way you would go about setting up a standard engine hopefully if i understand the process and concepts then i might understand these books on tuning, gotto start somewere
Old Oct 24, 2006 | 02:13 PM
CJBear's Avatar
CJBear
If it has a seperate thing for idle as the temperature goes up you would decrease the fuel values and what about ignition? how does a idle valve play into this? How do you make sure it stable in different conditions like high altitude or middle of artic weather or in the outback of aussie land.
Old Oct 24, 2006 | 02:24 PM
Idle valve control tends to be of closed loop operation.
So the further the idle strays from the required value the more the ICV opens to control it.
So if you are somewhere with less pressure (high altitutude) it would automatically compensate for that by being open a bigger percentage of the time.
Ignition as idle speed control is crude but some systems do it.
you basically set an "idle screw" of some sort to allow enough air in to idle on both a cold day or a hot day, and then you set the ignition to control the speed.
The way this works would be something like
500rpm 15 degrees
1000rpm 12 degrees
1500rpm 5 degrees
What this means is that if the revs increase, the ignition is naturally pulled further and further down as the ECU interpolates towards the higher rpm values which are less ignition.
Old Oct 24, 2006 | 07:41 PM
CJBear's Avatar
CJBear
AFR baffle me are you ment to target the same ratio for all revs and loads you mentioned 12:1 for non-turbo, other threads for turbos always mention 14.7:1?
Old Oct 24, 2006 | 07:45 PM
GARETH T's Avatar
GARETH T
you use different air fuel ratios for different applications,,,so different points in the map
this may help you
Old Oct 24, 2006 | 08:09 PM
CJBear's Avatar
CJBear
So if AFR not constant for all revs and load sites how do you know how rich or lean to make it?
Old Oct 24, 2006 | 08:56 PM
Stu @ M Developments's Avatar
PassionFords Creator
The same way an electronics engineer knows what components to use to make a circuit do what he wants i guess? Thats his trade and he has learnt exactly what works and what doesnt.
There are various rules to learn in any trade, AFR being one of them in a tuners.
Excuse my answwer if you actually meant "What AFR do you need for all the different loads" as oposed to what you actualy asked...
Old Oct 24, 2006 | 09:33 PM
POTENTIALLY WRONG RULE OF THUMB:
On boost hard = 11.5:1
On boost a little = 12:1
Part throttle economy 15:1
Thats a total ballpark to aim for, but can vary from engine to engine, and you need to do things such as monitor EGT to know whats happening.
Old Oct 25, 2006 | 07:34 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you need to buy dave walkers book and read it
Old Oct 25, 2006 | 02:30 PM
GARETH T's Avatar
GARETH T
totally agree,,(or we should bully stu to write his book ) it will give you an understanding of what and how ecu's work
http://www.amazon.co.uk/Engine-Manag...e=UTF8&s=books
Old Oct 25, 2006 | 04:38 PM
CJBear's Avatar
CJBear
On my shelf for months to be frank i felt a little out of my depth reading that got me fuzzooled the books aimed i felt at people with some basic knowledge and concepts in some sort of order me aint got a banana
Old Oct 25, 2006 | 04:40 PM
As you are in london its a shame you werent at the middlesex RSOC meet last month, there was some properly in depth mapping chat going on
Old Oct 25, 2006 | 04:46 PM
GARETH T's Avatar
GARETH T
the only person i got to bounce ideas of is my mother and jade
Old Oct 25, 2006 | 04:47 PM
Gareth, well come down to weston one sunday
Old Oct 25, 2006 | 04:50 PM
GARETH T's Avatar
GARETH T
i have promised to pop down one day,,, just dont seem to ever get there
Old Oct 25, 2006 | 04:51 PM
That is cause you are a CUNT
Old Oct 25, 2006 | 05:31 PM
CJBear's Avatar
CJBear
Not ready for hardcore mapping chat bud you lot would make me look smaller than my manhood
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
