fao anyone that knows ryan
right ho. my car is a 2wd saph into which im putting a level8 ecu.
it will have a msd coilpack conversion permenantely , so i was wondering if you can wire it up for the twin amps etc. i will be keeping the dizzy in place too.
the car will also have a 4x4 tps
also it will have closed loop fuelling so can you wire it up for the lambda sensor too. i havnt asked stu where to mount the sensor but im guessing it will be just behind the turbo? maybe you can enlighten me...
now for me being an awkward fucker. i wanted to have my fans on a switch inside the car so i can have them on whenever i want . so is it possible for you too make this up in the loom or even a separate loom?
any suggestions you have about the above would be a great help
hi tony, can do it no problem, but cant find those fan plugs anywhere.
only thing i can suggest is i replace those aswell? for a much more universal item?
sorry ryan not a high jack just there there if you know someone high on fords rally team or makes looms for them !!
Saphcos,
No problem about the Loom, Coilpack wiring is no problem either, same goes for TPS
Lambda as you said will be roughly around the turbo, so the bosch item will plug into it.
Now regarding the rad Fans, the ECU loom doesnt actually control these and its not part of the loom, but im sure i could provide something if you wanted?
Alternately i could offer you some advice as to wiring up an earth switch off you existing fan wiring?
CHeers
Ryan
CHeers
Ryan
bagginsRSturbo
49
27-09-2015 10:32 AM
