AP DISKS - A PROBLEM ?
Old Aug 26, 2004 | 03:38 PM
WayTooFast's Avatar
WayTooFast
Default AP DISKS - A PROBLEM ?
I recently fitted a brand new set of AP disks and 4 pots with DS2500 pads to my cossie.
The problem is, they squeal like a bee-ach when light breaking at low speeds.
The car has done over 1000 miles with them now and I bedded the pads in over about 200 miles.
The disks are in perfect alignment and fitted correctly including the retaining clips for the pads.
Does anyone know if this is normal or are my new bling brakes knackered ?
Old Aug 26, 2004 | 03:41 PM
zvhturbo's Avatar
zvhturbo
Have you lightly greased (with copper slip) the parts of the pad that are in contact with the calipers?
Also you can buy anti squeal pads to help stop it.
Old Aug 26, 2004 | 03:42 PM
WayTooFast's Avatar
WayTooFast
zvhturbo, I will try that - Thanks M8
Old Aug 26, 2004 | 04:07 PM
WutangRS's Avatar
WutangRS
i pretty sure they squel anyway, ive noticed alot of after market pads squeal due to higher metal compound in the pad
Old Aug 26, 2004 | 05:01 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
you have got to bed them in quite hard, i.e 4 or 5 heavy stops from 80-90 MPH then let them cool right down, then off you go also as said before copperslip on the BACK of the pad should quieten them down
Old Aug 26, 2004 | 08:45 PM
Neil S's Avatar
Neil S
If you are bedding them in as Wil says, don't let the car come to a complete stop!!! Only come down to about 5mph then go again
Neil.
Old Aug 26, 2004 | 08:50 PM
L33 BYT's Avatar
L33 BYT
Yeah copped slip is usually a good one. Check that you aint got a glaze on the pad also. If ya have get some real fine wet n dry and lay on a flat surface then rub the pad on it up and down still the glaze has gone.
Old Aug 26, 2004 | 08:52 PM
Disabled Account's Avatar
Disabled Account
Check that the pads have not been glazed............best to remove the pads (one at a time so as not to mix them up) then check the surface.......if they are shiney, it's best to rough them with sandpaper/emery cloth untill you get a matt finnish. At the same time clean the discs with brake cleaner.
Old Aug 26, 2004 | 08:53 PM
L33 BYT's Avatar
L33 BYT
Great minds Doug, great minds.
Old Aug 26, 2004 | 08:55 PM
Disabled Account
Yeah I know Lee
.....but as fast as I can type - I am allways a few seconds toooo slow
Old Aug 27, 2004 | 12:54 PM
WayTooFast's Avatar
WayTooFast
Thanks all - will have a good look when it stops raining
DAZZER
Sep 30, 2015 08:43 PM
Sp3no
Sep 27, 2015 07:23 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
