Can a BMW owner help please!
Hi ollie
I'm not sure for definate, but I use TWS in my E39 M5. It is quite expensive, but for mine, it is the only approved oil.
Snag is the only place you can get it is from BMW, or direct from castrol classic oils.
To be sure, I will post on my BMW forum board if you want and let you know
JJ
JJ
Right - done that. I am right, it has to be TWS oil.
I suggest you buy it direct from Castrol Classicv oils. It works out an awful lot cheaper!!!
Link below
JJ
http://www.castrol.com/castrol/secti...tentId=7003933
Link below
JJ
Team HOTHOT!
Originally Posted by EIL132
Originally Posted by AlexF
It should be run on Castrol RS (0w60 irrc)
Check on the castrol website!
Alex
Alex
Alex
Alex
"Do NOT use 10w-60 unless you have one of the following!
M43/CNG
S54
S62/E39 (Up to 02/2000)
If you do not have one of the above, you should be using the following:
0w-30, 0w-40, 5w-30 or 5w-40
As per the BMW Technical bulletin dated 1.11.2004.
Be careful out there as the Dealers don't read the bulletins either!"
M43/CNG
S54
Originally Posted by JjCoDeX75
Cant argue with that!
I would suggest that EIL is right, given that he runs not one, but two E36 M3's!
I bow to your judgement
JJ
JJ
My BM dealer in Devon area (I wont name and shame) pretty much try to sell the fully synthetic bloody expensive oil for all the cars across their range!
Even the old ones!!!
I do not necessarily trust them with the decision, though in my case with the M5, it was a little easier, given that there is only one oil that I am allowed to use! Doh!
JJ
JJ
CASTROL TWS for the EVO and 10w 40 for non evo (3.0l) thats from the M SECTION gmbh in germany as my sister lives there ad i found that out when i was there
Check the vehicle owners manual - it is full of valuable information that you may find very usefull
Thanks for all the replies!
One of the edge sports is now the recomended oil.
Cant remeber the grade now though and as I have sold it I cant check the reciepts
You need 'about' 6L of it
WD
WD
WD
WD
rsguy
44
29-09-2015 03:29 PM
