4x4 cossy parts for dax rush build (cossy breakers?)
Originally Posted by scruffythefirst
You building a quadra? Oh and north yorks rs spares always helped me out
Why did you choose a quadra over a 2wd out of interest?
already dyno'd @ 336bhp and that was very low boost
btw its not bought yet subject to getting all the parts and the green light from dax for engine mounting lugs etc
You dont really need to go 4WD with that power.
2WD will be fine for that BHP and a lot more.
A decent suspension setup and sticky tyres on a 2WD would be OK.
I know mines a westy, not a dax, but thats my two pence worth.
dax say performance is very good with a std 2.0l pinto. so i thought well its just gona be wheelspin tastic with big ish power ?
Well mines 230ish at the moment, on normal tyres and traction is very good. It'll slide about if you want but the LSD means its got plenty of grip. With the dax you can run 9" rims as standard and there are plenty of big power cossied dax's out there. I think stu mapped a 500+ one a couple of years ago. The trouble with the quadra's is they've got great traction off the line but are quite a lot heavier and can tend to understeer a fair bit. I'd go 2wd and camber compensation at the front if you can afford it. Get yourself down to dax and get gary to give you a ride out in the v8 or the turbo busa.
Well mines 230ish at the moment, on normal tyres and traction is very good. It'll slide about if you want but the LSD means its got plenty of grip. With the dax you can run 9" rims as standard and there are plenty of big power cossied dax's out there. I think Stu mapped a 500+ one a couple of years ago. The trouble with the quadra's is they've got great traction off the line but are quite a lot heavier and can tend to understeer a fair bit. I'd go 2wd and camber compensation at the front if you can afford it. Get yourself down to dax and get Gary to give you a ride out in the v8 or the turbo busa.
i just need a home for my well spent on/spec'd vauxhall turbo engine,mangement.
A dax would be ideal, they do fit XE's now so mounts are no problem, you can get bellhousings for XE to T5 and IMHO they look the best of the 7 type cars, and designed to handle the power straightaway without having to put extra bracing round the diff mounts etc. They've got bias brakes as standard, 9" rears fit straight off etc etc.....
Just make sure they know what your putting in it
Oh and that looks like an ideal power / torque curve. Nice and smooth, some of the old style stage 3 chips with a huge boost spike at 3000rpm can be a bit of a handfull in such a light car.
yeah dax said the extra length with the bellhousing adaptor is no problem
Re: westy
Originally Posted by leecavturbo
polly_x
any links to your car/build/spec
Not 100% sure on power really but the engine spec should be good for 450+.
I run nice soft rear setup with Toyo R888 tyres and does not really struggle with grip.
DixieTheKid
23-07-2023 10:16 AM
09-10-2015 07:38 PM
CabrioTurbo
01-08-2015 11:04 AM
