problem with dump valve i think.
Old Aug 24, 2004 | 04:42 PM
the madferrit's Avatar
the madferrit
Default problem with dump valve i think.
I fitted a dump valve to my car about 6 months ago and it has worked fine untill now.what happens is, when on idle the boost sits at about 0.2 below 0 where it used to sit well below that. It still boosts fine but there is no sound from dump valve when I release or change gear now. Instead its gone back to the chatter I used to get. I had the valve off and it moves freely enough. It is leaking a little air tho when on tickover. I assume its not the dump valve coz surly it would still work when boosting and releasing. I checked the seal inside and there was a small split so ive replaced it. all was fine for about 2 min then it stopped working again. I took it all apart again but all was fine. refited it and again it was ok for about a min then stopped working again. tryed refitting the standard valve but the same problem persists. not quits sure how these this work so what should i do now?
Old Aug 24, 2004 | 04:44 PM
Physio's Avatar
Physio
Bin it
Old Aug 24, 2004 | 04:45 PM
TIFF's Avatar
TIFF
Chasing Radders
The problem with it is that you have one
Take it off
Old Aug 24, 2004 | 04:53 PM
the madferrit
tried taking it off and putting the standerd thing back on but the same thing happens. boost guage still sits to high.
Old Aug 24, 2004 | 07:06 PM
the madferrit
any1 any more ideas?
Old Aug 24, 2004 | 07:10 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
dont put ANY on not even std! shuldnt u be cgetting a bit of vaccum on the boost guage at idle?
Old Aug 24, 2004 | 10:41 PM
the madferrit
im getting just below 0. before when it was working fine i was getting .6 below 0. what do i do about all the connections if i dont put any on?
Old Aug 25, 2004 | 09:59 PM
Dave McB's Avatar
Dave McB
block the connections off.
The prob is def the d/valve. Sounds as if there is still an airleak if the guage aint where its supposed to be...
Old Aug 25, 2004 | 10:25 PM
SmokeStoner's Avatar
SmokeStoner
Have you checked all the vacuum pipes?
Are you sure there is not a split in one of them?
I know when one of my vacuum pipes come off on the saph, it would still boost properly, but the woosh from the valve was pathetic and i got chatter aswell!!!
Couldn't tell ya about the gauge though, i ain't got one yet
15
Oct 7, 2015 03:43 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
