Boost Adjustment
Old 29-09-2006 | 06:00 PM
trevCOSS's Avatar
trevCOSS
Default Boost Adjustment
Right I have a question I want answered if possible, I have an Idea what the answer might be and its probably not what I have done.
What is the correct way to adjust boost and why, before anyone starts lets assume we are talking about adjusting within the recommended limits of a given chip, and that the fuel system is capable as is the turbo.
So A few examples
1. Adjust the pre tension on the waste gate actuator till desired boost is acheived.
2. (cossies and rs turbos) adjust size of the restrictor in the bleed of from the amal valve.
3. Fit a bleed valve.
4. bit of a cost option this one, fit air injectors and get mapped to suit or fit an aftermarket boost controller of some kind.
Im sure the last option is quite possibly the best but also the most expensive, which of the other 3 is the correct way and as mentioned why.
Old 29-09-2006 | 06:19 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Option 4 you pikey
Old 29-09-2006 | 06:21 PM
trevCOSS's Avatar
trevCOSS
Originally Posted by B9KOS
Option 4 you pikey
Doesnt really answer my question does it
Old 29-09-2006 | 06:23 PM
xrchris's Avatar
xrchris
i've been told that adjusting the pre-load on the actuator is quite a reliable way and thats how my mates gonna set mine up
Old 29-09-2006 | 06:25 PM
trevCOSS's Avatar
trevCOSS
And thats how I have done mine but I have my doubts that its the right way, hence the question
Old 29-09-2006 | 07:32 PM
Andreas's Avatar
Andreas
I would follow these steps....
1. Set preload on actuator, "half a hole".
2. Replace AMAL-valve jet.
3. Fine tune boost by adjusting actuator rod lenght.
By fine tune, I mean adjusting the rod length a turn, or a half.
Old 29-09-2006 | 07:48 PM
trevCOSS's Avatar
trevCOSS
ok I understand that, except replace jet how and with what, my local tuner always seems to set just using the pre load! Is there certain jets to acheive certain boost? and why cant it just be done with a bleed valve or with the pre tension, I prefer to have an understanding as to why I should /shouldnt do something.
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Fezman1
02-10-2015 01:22 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Boost Adjustment
