Fuel pump rewiring
Visitor from the Darkside
I am rewiring my saff 4x4 fuel pump as I have fitted an 044. I was wanting to take the feed from the ecu but I am not sure which pin it is. I think it is pin 28 but I am not sure if that goes +12v or switches to earth.
Thanks
Graham
Thanks
Graham
Get on That!
don't need to take wire from ECU just run a fused live from battery with a 30amp cable and use a normal 12v relay and wire it as per diagram job not forgetting to run some new earth wires also
![](http://www.cruisewestcumbria.info/cossiematt/various/fpwiring.jpg)
Hi mate thanks for the reply.
Does it have to come from the inertia switch or can the feed come direct from the ecu? What benefits are there either way?
Graham
Graham
The feed from the inertia switch is only switching on the new relay,so your new feed wire to the battery is feeding the actual pump ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
This by-passes all the shit old wiring that feeds the pump
If you don't use the inertia switch you have got no protection in an accident,the pump will just keep running and spray petrol everywhere
Don't really see where your coming from with the ECU feed question?
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
