Where can i get a fuel regulator that adjusts upto 90psi
Old 25-09-2006, 04:13 PM
Scott R
Scott R's Avatar
Default Where can i get a fuel regulator that adjusts upto 90psi
I am after a fuel pressure regulator that will adjust upto 90psi
At the moment i cant seem to find one?
Its for my RS16i track car ( ex touring car) it uses this regulator in place of the warm up regulator. I cant describe exactly how the system works, but the short of it is i need fuel pressure at approx 80-90psi at that point in the fuel line, as the K jet uses two pressure systems, a control pressure and system pressure, by adjusting one it increases the engines power.
Thanks for any input/suggestions
I would also prefer one with a guage attached but its not essential as i can fit an in dash guage if needed.
Scott
Old 25-09-2006, 06:46 PM
DazC
DazC's Avatar
Does the Aeromotive regulators not go that high?
I doubt you will get one for 90p though Scott!!
Old 26-09-2006, 07:42 AM
Scott R
Scott R's Avatar
yeh i know,
Its what i was told i would need, the pressure i need to run is approx 81-84psi, so was after one that went slightly higher just in case it needed it
Do you know if there is an importer of the aeromotive stuff?
JK12
33
26-04-2021 12:09 PM
timsrs
13-11-2018 11:48 AM
155lee
27-10-2015 04:55 AM
IainRS1700T
25-09-2015 06:44 AM
Dubs44
19-09-2015 06:31 AM
Quick Reply: Where can i get a fuel regulator that adjusts upto 90psi
