steel rods in engine question
Old 24-09-2006 | 05:27 PM
stevenebm's Avatar
stevenebm
post whore
Default steel rods in engine question
say i wanted steel rods in my engine.would it be an engine out job or could somebody do it with the engine still in the car?cheers guys
Old 24-09-2006 | 05:28 PM
xr4x4rs's Avatar
xr4x4rs
engine out mate and complete strip down
as the pistons have to come out with the rods to change the rods over
Old 24-09-2006 | 05:35 PM
stevenebm's Avatar
stevenebm
post whore
a thot so mate
Old 24-09-2006 | 05:36 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
If you really wanted to do it in situ you could remove the sump and unbolt the big ends then withdraw the piston and rod from the top once you have removed the head.
Old 24-09-2006 | 05:49 PM
stevenebm's Avatar
stevenebm
post whore
that sounds a lot easier?would it be easy to remove a zetec head when its in a series one engine bay.limited space
Old 24-09-2006 | 05:53 PM
Martin-Hadland
If I were doing the job i would rather remove the engine, it might be faster.
Old 24-09-2006 | 06:03 PM
As above, its POSSIBLE to do in the car, but given that at the same time you are likely to be also changing bearings and probably wanting the crank polished, i would take it out personally.
Old 24-09-2006 | 06:24 PM
stevenebm's Avatar
stevenebm
post whore
cheers guys.
Old 24-09-2006 | 06:33 PM
Rs1's Avatar
Rs1
Personally i'd whip the sump off,whip the rod caps off and have a squint off the bearings/crank. If there good i'd leave the engine in a just whip the head off.
Old 24-09-2006 | 06:47 PM
Rossco's Avatar
Rossco
Thought you had a fully speced engine already
Old 24-09-2006 | 06:54 PM
stevenebm's Avatar
stevenebm
post whore
yeh but without steel rods
Old 24-09-2006 | 11:11 PM
Rossco's Avatar
Rossco
375 BHP on standard rods is gonna end in tears
Old 24-09-2006 | 11:54 PM
Ex-Finesse's Avatar
Ex-Finesse
Jesus, 375!
Who specced the engine mate?
And who was bold enough to map it so far?
Old 25-09-2006 | 05:20 AM
CliffRS4's Avatar
CliffRS4
Steel rods make a hell of alot of sense with that power
Old 25-09-2006 | 08:29 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
FLOODS of... !
Old 25-09-2006 | 08:44 AM
DanS's Avatar
DanS
My rods where installed with the engine in situ (first time round ). Bit of a bugger getting the sump+gasket back on so I've heard though!
Old 25-09-2006 | 11:08 AM
Rossco's Avatar
Rossco
Steve what drivers side engine mount did you use?
RUBY123
22-10-2023 01:04 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 10:54 PM
Caddyshack
19-08-2015 08:29 PM
