Diff recommendations
Old Sep 17, 2006 | 02:39 PM
jbrayley's Avatar
jbrayley
Default Diff recommendations
I have an Escort Cosworth currently running 500bhp (with a possiblility of goign to 600bhp in the near future) with ATB Quiafe diffs. I am scared that these diffs will let go if I launch the car, and was wondering what my options were within a 5k budget for front and rear
Old Sep 17, 2006 | 03:57 PM
markk's Avatar
markk
you have not mentioned what gearbox you have ?
the 5K will get you nothing if you havnt already got a box to handle 500hp nevermind 600hp
with the rear diff, you only have 2 real options, stick with ford and use the 9" ( there goes most of your 5k ) or use a non ford item for considerably less,
the front fit the 8.5" group a diff sump and crossshaft ( 4.5K)
these are your only real guranteed reliability front and rear diffs, all others are just holding in there waiting to break, you get what you pay for.
all use dependant of course, if you just go shopping with your 600hp and never come on boost then just stick to std
Old Sep 17, 2006 | 04:11 PM
Disabled Account's Avatar
Disabled Account
Markk
Jay purchased Kev McSharp's FFD box......you should know this by now.........
because a few of us did remind you
https://passionford.com/forum/viewto...light=#3158082
Old Sep 17, 2006 | 04:16 PM
markk's Avatar
markk
like that was important enough for me to remember
so , the score looks even better, the guy has got the dogs bollox of a gearbox to begin with top bloke
so save yourself a bit more cash, up the 5k to 7.5k and you have then got the best transmission ever designed for a cosworth - fit and forget
then unleash your 600hp with a worry free status
Old Sep 17, 2006 | 04:38 PM
jbrayley's Avatar
jbrayley
Hi Mark, thanks for the advice. How much does the 8.5 inch group a diff cost? Will this involve a lot of engineering (i.e. moving the engine etc?) Also where would I get one from? What ratios should I go for, seeing that this is goign to be a road/track car with emphasis on track
Old Sep 17, 2006 | 04:50 PM
markk's Avatar
markk
have a chat with tim finch, i think he may have just what you need pal
ive no internet access from now on for a week or so but im sure tim will advise you
Old Sep 17, 2006 | 04:57 PM
jbrayley's Avatar
jbrayley
Thanks mark
Old Sep 17, 2006 | 06:44 PM
Fiecos Dan's Avatar
Fiecos Dan
You wont have problem's with a ATB,
I've never heard of one breaking, unless its old, worn and un serviced.
Old Sep 17, 2006 | 08:22 PM
jbrayley's Avatar
jbrayley
Thats what I thought, but Kev Sharp who sued to run the gearbox I have broke a few with hard launches
Old Sep 17, 2006 | 08:27 PM
Kevin Sharp's Avatar
Kevin Sharp
i have broken everything there is to break on 4x4 transmissions i think!, when i fitted the box i also bought a 9" diff to fit after advice from dennis at dome....as the FFD prop has no doghnut it is very harsh on diffs
Old Sep 17, 2006 | 08:33 PM
Kelv's Avatar
Kelv
Almost there!
What costs are involved with the rear beam to go with the 9" rear diff?
Old Sep 17, 2006 | 08:38 PM
Tony Ryan's Avatar
Tony Ryan
A std 2wd rear axle will take a 9" diff , no need to buy anything exotic .
Old Sep 17, 2006 | 09:20 PM
Kelv's Avatar
Kelv
Almost there!
Cheers Tony.
as simple as that.
no welding of carriers as maybe sugested above - any other special fabrication required to make it all fit, other than a prop id guess.
obviously using the 2wd beam the 2wd arms etc will all be required aswell but do they meet up perfectly with the 9" diff atall.
Lots of questions from myself, decided transmission is going to be the next big spendauture so gathering as much info as i can.... Cheers
Old Sep 17, 2006 | 09:44 PM
marco polo's Avatar
marco polo
Hi Mate
you have got about 4 choices
uprated VC lsd with uprated planet gears 7 or 7.5
Atb 7 or 7.5
plated diff 7 or 7.5
9" diff either uprated VC or plated
don't forget your car is a 4wd so you only have about 70% that goes to the rear wheels
with all the 7 and 7.5 diffs i have mensioned the weakest link is the CWP even shot peend they can still break
saying that i haven't broke a CWP yet on my 7.5 plated diff and thats 100% rwd
if your after an uprated box new big tooth striaght cut mt75 box we are testing them now
have alook on here how progress is going
https://passionford.com/forum/viewto...985&highlight=
cheers Marco
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Topjoe9
Sep 12, 2015 09:50 AM
Fezman1
Sep 7, 2015 09:34 PM
