FAO People with 4wd cars and 2wd Heads fitted
Old 08-09-2006, 08:05 PM
tracktoy
tracktoy's Avatar
Default FAO People with 4wd cars and 2wd Heads fitted
how have you mounted your Oil Pressure switch and oil feed to the turbo???
as i can't get mine to fit as the oil filter is in the way
switch/feed pictures if possible please
Old 09-09-2006, 02:13 PM
Spiky
Spiky's Avatar
anyone?
Old 09-09-2006, 02:37 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
i used aeroquip connections, 90 degree bend with 1/4 bsp thread into the block.then onto the turbo.then just T the oil pressure switch into the line where you want it.
Old 09-09-2006, 02:39 PM
xr4x4rs
xr4x4rs's Avatar
can you not take the remote filter housing off and just put the filter on the block
or is the subframe in the way
Old 09-09-2006, 02:42 PM
Lloyd
Lloyd's Avatar
the engine mount is in the way.
Old 09-09-2006, 02:56 PM
3drstretch
3drstretch's Avatar
can you use a smaller filter
Old 09-09-2006, 03:10 PM
sjm
sjm's Avatar
i have the 205 in a 2wd, i had trouble but, there are two filters available a 70 something mm and a 90 something mm, the smaller one of the works ok.
Old 09-09-2006, 06:30 PM
Spiky
Spiky's Avatar
no, cos the pressure switchs catah's the rim on the filter when it's on
some ideas there, cheers all
also can't take connect filter to blocks either there will be no room or no cooler
Old 09-09-2006, 07:27 PM
PAUL S
PAUL S's Avatar
loosen slightly the remote filter housing where it connects to the block ( big nut), raise it up about 10mm and then shim under the bracket where it bolts to the engine mount arm with washers, and refix using a longer bolt and retighten the big nut.
This should give you enough room to use the standard 2wd oil take off block with the oil pressure switch and turbo oil feed installed without fouling the rim of the filter.
I did this about 4 weeks ago with mine and it works fine
Old 09-09-2006, 08:16 PM
Fiecos Dan
Fiecos Dan's Avatar
i use a 4wd head, but wanted a oil feed for the turbo at the pressure switch, as cleaner and better supply there.
i use std ford oil filter etc etc.
Heres my setup.
Old 09-09-2006, 08:45 PM
PAUL S
PAUL S's Avatar
Old 10-09-2006, 09:39 AM
Butch.
Butch.'s Avatar
Old 10-09-2006, 10:22 AM
Spiky
Spiky's Avatar
cheers guys,
hopefully now we'll be able to sort it
Old 10-09-2006, 01:28 PM
PAUL S
PAUL S's Avatar
meant to say make sure you are using the thinner 4x4 oil cooler modine rather than the thicker 2wd one otherwise incoming oil bypasses the filter
Old 10-09-2006, 02:31 PM
Fiecos Dan
Fiecos Dan's Avatar
Whys that?
Old 10-09-2006, 03:17 PM
PAUL S
PAUL S's Avatar
using the thicker 2wd modine means that the threaded insert which goes into the block and attaches to the big nut of the oil remote filter housing does not seal fully internally leaving a small passage for some of the incoming oil to bypass the filter and mix with the oil that is returning from the filter back into the galleries of the block.
Old 10-09-2006, 06:39 PM
tracktoy
tracktoy's Avatar
cheers everyone
am i right in saying that the block is a 1/4 npt thread???
Old 10-09-2006, 06:45 PM
Fiecos Dan
Fiecos Dan's Avatar
Oh.
do you know the difference in thickness? so i can check mine.
as i've always thought 2wd and 4wd's were the same.
Old 11-09-2006, 01:09 PM
Spiky
Spiky's Avatar
Originally Posted by 3dr-rally-slag
cheers everyone
anyone know the answer???
Old 11-09-2006, 01:12 PM
IANS2RST
IANS2RST's Avatar
u can use a zetec escort filter which is longer but thinner, fits fine on my 4x4 with the 2wd oil feed arrangement
Old 11-09-2006, 01:18 PM
Spiky
Spiky's Avatar
you have any pics??
Old 11-09-2006, 05:05 PM
tracktoy
tracktoy's Avatar
cheers for your help guys but i think i git it sorted
have used the 2wd adapter and turned it through 90 degrees as suggested by spiky
now looks like this and clears the filter no problem
Old 11-09-2006, 05:25 PM
Spiky
Spiky's Avatar
awesome
Old 11-09-2006, 08:31 PM
tracktoy
tracktoy's Avatar
Originally Posted by fiesta cossie
Oh.
not sure of the exact measurments but the 4wd water connections are in line with each other and the 2wd ones are offset slightly
Caddyshack
15
04-08-2015 08:50 AM
RIB1122
03-08-2015 09:20 AM
lockie
31-07-2015 10:03 PM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
Quick Reply: FAO People with 4wd cars and 2wd Heads fitted
