Another question for the Physicists/Mathematicians on here ?
Can you explain in laymans terms how to work out centrifugal forces ?
Heres the problem. I have to make a flywheel that has an external balance factor, this flywheel will be a smaller dia than the one it's replacing (actually a flex plate but you get the idea)
![](https://img.photobucket.com/albums/0703/escortrs2300/balance1.jpg)
I can measure the size of the weight but if I'm thinking right the weight will have to be increased as the radius decreases
How do I work out that if I move the weight in X amount how much material to add?
I only need to get fairly close as it will be balanced on the engine later, it's the not knowing thats frustrating!
cheers
Mark
cheers
Mark
