data logging devices
does anyone know of any external type of data logging device that can monitor what the ecu see's and obv records it under live conditions ? ecluding the pectel monitors as 99% of the data log functions on the monitors dont seam to work anyway
i dont want to be changing ecu ( from P8), i need to be able to record at a decent rate for a good hour or so, i need to monitor egt, afr, cts, cat, tps, map, rpm, inj duty, as a bare minimum really.
regards
regards
there are plenty of devices around, but they won't speak to the ECU, just work independantly taking inputs from the sensors.
I use innovate stuff to log all the things you mention and more.
foreigneRS
pretty useless unles your gonna carry a laptop around with you
cant see the scrutineers going for that one, nor do i like the idea of it hitting me on the head over a large crest
sibster
are gems actually sending stuff out this millenium ian
Doug
pretty much comes down to usability/fitment into the car really pal - and they dont !!
im not bothered about it actually having coms with the ecu, just need a device that will show real time and record it - any links appreciated
i would just use an old laptop running the RP Labs Monitor software
sibster
Spend some wonger you tight fisted bugger....get a gems cd22 and combined data logger....they're dirt cheap
Doug
What about a 4 line snap on scanner this will give you live data and logger
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
