Does Bore Affect CR?
Old Aug 31, 2006 | 05:48 PM
_DAN_'s Avatar
_DAN_
Yoon
Default Does Bore Affect CR?
As above really geezer on E36coupe forum reckons it does.
Is he right or is a coming his way?
Right confused myself here.
This is what he said.
The trouble with this engine is that the bore is maxxed out pretty much, look at the increase between 3.0 and 3.2, it's all in the stroke. That's also the reason the compression ratio goes up, the cylinder chamber volumes are the same. If you look at this engine with the head removed there's a tiny gap between each piston.
So any increase in capacity will come from an even futher increase in stroke that wouldn't neccessarily be the right thing. Also the compression ratio would need adjusting etc. etc.
Old Aug 31, 2006 | 06:04 PM
Rs1's Avatar
Rs1
I would say so............i should increase comp ratio i reckon
Was wondering what Bord was earlier
Old Aug 31, 2006 | 06:05 PM
_DAN_'s Avatar
_DAN_
Yoon
Yeah mate mind all over the place tonight
Old Aug 31, 2006 | 06:06 PM
richard_syko's Avatar
richard_syko
Yes, because your changing the volume.
Old Aug 31, 2006 | 06:11 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Yes bore does have an effect on C:R but so do alot of other things such as swept volume, combustion chamber volume, deck height volume, gasket volume, piston volume, etc. etc...
Old Aug 31, 2006 | 06:16 PM
_DAN_'s Avatar
_DAN_
Yoon
Cheers my mids over the place tonight
Thought about it and yeah he's right.
Old Aug 31, 2006 | 06:26 PM
richard_syko
Old Aug 31, 2006 | 11:27 PM
Only TWO things effect the CR ultimately.
Change in swept volume
Change in unspwept volume
Boring an engine increases the swept volume and therefore increases the CR
(assuming the same cc piston dish etc)
TPM961
Jan 15, 2018 10:50 AM
20/20 vision
Sep 28, 2015 03:03 PM
SMILER258
Sep 28, 2015 09:04 AM
104
Sep 26, 2015 07:40 PM
