DISCONNECTING KNOCK SENSOR ANY PROBLEMS???
Old Aug 31, 2006 | 05:08 PM
IANS2RST's Avatar
IANS2RST
Default DISCONNECTING KNOCK SENSOR ANY PROBLEMS???
does disconnecting the knock sensor on either the series 2 rst or 4x4 sapphire cos have any effect on the running of the car??
Old Aug 31, 2006 | 05:11 PM
Rick's Avatar
Rick
Not sure about the Saph, but it'll run like shit on an S2
Old Aug 31, 2006 | 05:13 PM
IANS2RST's Avatar
IANS2RST
in what way?
Old Aug 31, 2006 | 05:14 PM
Rick's Avatar
Rick
the ignition is retarded massively, so it feels very flat as soon as you start to come on boost.
Old Aug 31, 2006 | 05:15 PM
originalcabbie's Avatar
originalcabbie
The knock sensor detects pinking of the engine, if i remember rightly so, and disconnecting it puts the ECU into limp home mode i.e low boost and lumpy.
Not a good idea unless you have S1 loom and ECU or a S1 ECU.
Old Aug 31, 2006 | 05:20 PM
ECU Monitor Enthusiast
If you disconnect the sensor, the wires act like antennas and pick
up noise which can fool the ecu into thinking you have detontation
resulting in poor performance due to ignition retardation.
If you disconnect it, short out the two connections together
(not the screened cable part - leave this alone) and this will result in no
electrical noise being sent to the ecu and the car will run ok.
Old Aug 31, 2006 | 05:30 PM
IANS2RST's Avatar
IANS2RST
if thats the case with the wires picking up interferance then what about using a series 2 ecu on a series 1 which doesn't have any wires for the knock sensor?
Old Aug 31, 2006 | 06:06 PM
Should be ok in that setup.
Old Aug 31, 2006 | 06:08 PM
IANS2RST's Avatar
IANS2RST
why do a lot of people say that the series 2 ecu is not compatable with a series 1 car?
also what about the 4x4 sapphire?
Old Aug 31, 2006 | 06:41 PM
The series 2 RST car had more sensors and a different ignition offset in
the software. (2 degrees different if I remember correctly).
If you use a S2 ecu on an S1 then the sensors that are need wont
be there and you will get unpredictable results.
This also depends on the chip fitted in the ecu too.
The extra sensors are a temperature sensor an the knock sensor.
You could retro fit the extra S2 sensors (with or without knock) then use
the newer ecu on the car and the dizzi adjusted correctly.
As for cosworth ecus, should be ok to swap as long as you understand the
other issues that need sorting apart from the knock sensor.
(TPS type, Lambda sensor etc...)
Old Aug 31, 2006 | 07:42 PM
davidreader5's Avatar
davidreader5
simon,
What temp sensor's are you saying, as both s1 & s2, have cts & act sensors, although no knock sensor on s1 or early s2's.
Dave R,
Old Aug 31, 2006 | 07:43 PM
On the S2, there is a SECOND coolant temp sensor for the ignition ecu.
Old Aug 31, 2006 | 07:53 PM
davidreader5
SIMON.
What year approx as i've had 8, S2, where was it fitted, was it still in the inlet manifold or pipe in the waterways, as have only seen the one CTS,
only difference between s1 & s2 was the thread, i assume the resistance
stayed the same, without checking it,
Dave R.
Old Aug 31, 2006 | 08:17 PM
On my G plate S2, I had two coolant sensors.
The second was located next to the original on the rubber pipe in a brass
boss behind the inlet manifold.
If you look in the Haynes manual, it is clearly marked on the ciruit
diagram.
From memory, my silver ecu was hearts and diamonds type.
Old Aug 31, 2006 | 08:22 PM
Rick's Avatar
Rick
S1 has 2 temp sensors too, one for each ECU.
You can't run an S2 ecu on an S1 without a knock sensor. It will still retard the ignition. You can compenstate to a degree with the dizzy, but it will never be right. This goes for shorting the knock sensor wires too. Sending 5v straight back to the knock sensor input will have a an effect on the ignition timing too.
Old Aug 31, 2006 | 08:25 PM
Rick,
The knock sensor isnt fed with 5 volts . Its a piezo electric crystal that
generates its own AC voltage from vibrations. !
Shorting it will work
Old Aug 31, 2006 | 08:30 PM
Rick's Avatar
Rick
Yea, ur right. I was just going off the colour code - think it's a black and yellow feed, which is supposed to be a common feed to all sensors.
Shorting it doesn't seem to work though. I've set up a few, which have been acting up for no apparent reason. Under further investigation, the insulation had begun to come away from the sensor, and the wires shorting. Sepertating them cures the problem.
It's as if the ECU needs a waveform from a "normal" sounding engine to work correctly. Knock sensors give endless greif. If it was so easy, then tuners would just short the wires.
Old Aug 31, 2006 | 08:33 PM
Rab's Avatar
Rab
Fucking superstar........
I just remove it from the engine and wrap it in bubble wrap.
Old Aug 31, 2006 | 08:37 PM
scud's Avatar
scud
i have a 4x4 cosworth engined sierra, about five or so years ago i noticed the knock sensor wireing had rubbed showing the inner cable. i have used the car ever since with it disconnected and havent had any problems
Old Aug 31, 2006 | 08:47 PM
EIL132's Avatar
EIL132
Old Aug 31, 2006 | 08:56 PM
Rick's Avatar
Rick
that doesn't always work either
Old Sep 1, 2006 | 06:22 AM
originalcabbie
Have you had any boost problems ?? i.e. low boost or pinking at high boost?
Old Sep 1, 2006 | 07:07 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
rf interference is a big issue on knock sensor erst ecu's
there are also different types of s2 knocksensor ecu's
fitting a non knock sensor early ecu cures the problem.The knock sensor stratergy can go hay wire and takes 11 degrees out of the current ignition load site .
The erst knock sensor ecu has no default stratergy for knock sensor issues so 11 degree's comes out ,this is ok on part throttle light load situations as the ignition timing can be as high as 50 degrees advanced at this point.But at 10 psi the ignition timing is typicaly 10 degrees of advance and the engine does not like 11 degrees taking out.
The knock sensor can be removed and wrapped and tied away from the engine you can also install a 47 k resistor and throw the knock sensor away .
Cosworths don't really have these issues better ecu better maps better default stratergies.
Old Sep 1, 2006 | 08:11 AM
L1 / L6 / L8 dont have a knock sensor though, or is that what you mean by better strategy?
Old Sep 1, 2006 | 08:23 AM
Graceland's Avatar
Graceland
Team HOTHOT!
L8 DOES have a knock sensor Chip - its located on a 200 block just to the right of the coolant drain bung
Old Sep 1, 2006 | 08:31 AM
Ah, mine is on an L1 or L6 loom by the looks of it then so doesnt, lol, cheers for the though, sounds deserved.
Old Sep 1, 2006 | 08:32 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Been wanting to use that one against you for aaaaaaages
Old Sep 1, 2006 | 08:35 AM
Well have one of these for being so sad
Old Sep 1, 2006 | 08:36 AM
Graceland's Avatar
Graceland
Team HOTHOT!
bitchwhore
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
BRAM
Sep 8, 2015 07:11 AM
