Ahmed style fuel pump fitting kit.... MikeR maybe?
Old 31-08-2006, 10:17 AM
Franco
Franco's Avatar
Default Ahmed style fuel pump fitting kit.... MikeR maybe?
Anybody had any dealings with fitting these, i've had a kit for a while but never got round to connecting it properly!
Am i right in thinking i need to remove all the bits as indicated in this pic?
Also the kit doesnt look like its complete? how many washers should i have?
This might be a job for Suparainbird!!
Old 31-08-2006, 10:28 AM
The DIVA
The DIVA's Avatar
How long has that lasted...
Jay... you need to remove the pipe and that part of the bracket you have indicated......then enlarge the hole where the pipe was big enough for the fitting from the new kit.....
Then simply build it up as per instructions...
If you haven`t got any destructions mate i can take a pic of mine later and show you how it`s done.....
Old 31-08-2006, 10:34 AM
Franco
Franco's Avatar
HOW VERY DARE YOU!
True blue peter styleee!!
Yeah if you could Rob, i just dont want to start cutting up the sender unit then end up fcuking it completely!
Ps where's Rainbird when you bloody need him!
Old 31-08-2006, 10:36 AM
Disabled Account
Disabled Account's Avatar
This is a Bosch pump with the full fitting kit that Mike R supplies:
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
I'm forever being asked for these, so could you please email me the picture so I can send it off with the kits . A picture speaks a thousand words and saves me typing it all out .
Old 31-08-2006, 10:40 AM
RichardPON
RichardPON's Avatar
Dave would have a fit if he saw this post again
The DIVA
The DIVA's Avatar
Will do Mike,going up to the workshop shortly so will show everyone how the pro`s do it...
Thats`s if i can find one...
Old 31-08-2006, 10:48 AM
Franco
Franco's Avatar
Shhuuuusssh!
Dont tell him!!
Old 31-08-2006, 10:52 AM
Franco
Franco's Avatar
Well in my kit i never got the bits indicated below!
Looks like i need a chinwag with Mr Rainbird!
Old 31-08-2006, 10:53 AM
DaveEscos
DaveEscos's Avatar
Shhuuuusssh!
Dont tell him!!
Old 31-08-2006, 11:00 AM
Mike Rainbird
Caraholic
You haven't lost some bits already ?
Old 31-08-2006, 11:05 AM
Franco
Franco's Avatar
In all honestly Mike, i havent used the kit until yesterday.....
The nuts supplied never fitted the 023 pump, nor did the connectors!
Have you got any more washers laying around you could stick in the post?
DaveEscos
I was waiting for that!!
Old 31-08-2006, 11:08 AM
Mike Rainbird
Caraholic
If I split a kit here to give you the two washers you have lost, then I will have a kit like yours .
The blue and red end fitting, I don't supply any more .
Old 31-08-2006, 11:23 AM
Franco
Franco's Avatar
Pah talk about customer satisfaction!!!!!!!!!
Old 31-08-2006, 11:24 AM
Franco
Franco's Avatar
Ps i never fooking lost them............ You just cant count! Must of been too much pimms when you put that kit together!
Old 31-08-2006, 11:27 AM
Mike Rainbird
Caraholic
The kit comes in a sealed polyethene bag direct from my supplier - all I have to do is look to see if it is complete (which yours WAS) and then send off .
I bet when you opened it, you did like a hasty child opening a bag of crisps and the bits went flying EVERYWHERE . Have a look on the floor where you opened them .
Old 31-08-2006, 11:34 AM
Franco
Franco's Avatar
And you're willing to bet your life on that Mr Rainbird............ That ONE kit might have slipped through you're bleary PIMM'D up eyes!
Anyway email sent!! [/b]
Old 31-08-2006, 11:45 AM
The DIVA
The DIVA's Avatar
Actually mine was the same as Jay`s......
Only one doughty washer as well.....
Ok chaps,here is one fitted....You will notice that rather than cut the end on my 90 degree fitting,i have spaced the fitting with soft copper washers to drop the fuel pump to the same level as the return pipe....This will hopefully give a little bit less chance of surge as the pump is lower in the swirl pot but not too low so as to be restricted by the swirl pot base....
Works great and i`ve had it on the test rig up to 5 bar with no leaks...
Old 31-08-2006, 11:46 AM
RichardPON
RichardPON's Avatar
The bits missing just look like a straight -6 and two o-ring washers.....
Franco
Franco's Avatar
OH FUCKING REALLY.............................
You comments Mr Rainbird before we set the lynch mob on to you!!!
Cheers Robbie, true gent amongst this riff raff!!
Old 31-08-2006, 11:50 AM
MONSTER
MONSTER's Avatar
Old 31-08-2006, 11:54 AM
Mike Rainbird
Caraholic
You both must be useless at opening bags, as I'm never wrong .
Old 31-08-2006, 11:59 AM
The DIVA
The DIVA's Avatar
Old 31-08-2006, 12:46 PM
Franco
Franco's Avatar
Me & Robbie must be all fingers & thumbs when we recieve small packages from Mike!
Old 31-08-2006, 12:53 PM
Mike Rainbird
Caraholic
I don't want to know about your sordid sex lives thank you very much . What you do with the packages in the privacy of your own homes, is your business .
Old 31-08-2006, 12:56 PM
Franco
Franco's Avatar
Old 31-08-2006, 02:14 PM
The DIVA
The DIVA's Avatar
Poor old Mike and his "Small Package".....
Old 01-09-2006, 08:38 AM
Franco
Franco's Avatar
Right too late now as its all done.....
Wasn't too keen on using so many washers to space it under the return pipe so ended up using an old rubber rad mount to absorb the uneven feel of the underside of the sender.....
Brass washers fitted on every join except at the top.
Only thing that concerns me is that the fuel level bob now doesn't quite reach its final position (as it hits the pump)..........
Should this amount of discrepancy be anything to worry about
More pic's of the work in my resto thread if anybodies interested.
Any input appreciated!
Thanks
Jason
Old 01-09-2006, 08:45 AM
Disabled Account
Franco
I would use the correct high pressure sealing washers as you dont want any pressure leakage AFTER the pump - for obvious reasons
Your 4 - 5 BAR line pressure MAY WELL cause a leak from that rad spacer washer shown.....also you dont know if the rubber is made from petrol/vapour resistant material - it could turn it to a blob of sludge with time.
Old 01-09-2006, 09:00 AM
Franco
Franco's Avatar
Franco
Your 4 - 5 BAR line pressure WILL cause a leak from the rad spacer washer shown.
Explain how that would happen Doug? as the top of the pump (working down) has a H/S washer fitted. Then after the sender part the tight fitting rubber bung, then a brass washer - Fitting tube - Brass washer - then the pump itself.......
Fear not captive audience, it can all be changed no bother!!
And there was me all proud of meself last night!!
Old 01-09-2006, 09:44 AM
Disabled Account
I know that the rubber is quite hard, but with 4 - 5 BAR line pressure it will distort and let fuel past.
The fuel wont be wasted as it will drip down in to the tank, but I think the pressure will be affected
Old 01-09-2006, 09:51 AM
Franco
Franco's Avatar
Yes Doug...............
So can i space this correctly with just washers? As the kit i got off Rainbird only can with one seling washer.... Or do i get a handful of them to replace the rubber mount.
Learning curve this!
Old 01-09-2006, 09:52 AM
Franco
Franco's Avatar
WTF happened there, when i replied all i saw was a picture!!
Old 01-09-2006, 10:00 AM
Disabled Account
I edited to explian why I think it will cause a problem - as you asked.
To answer re the use multipile washers: Well, that may be better than what you have now, but still a "bit" of a bodge IMO..........
Why cant you get Mike R to send you some of the correct items?
Old 01-09-2006, 10:32 AM
Franco
Franco's Avatar
Because according to him, me & robbie got excited and lost a few!
Bless.
Ok i can totally see where you're coming from Doug but..........
The areoquip fitting runs through all the washers, rubber mounts straight to the billet tubing which is all tight. Thus i cannot see where the pressure will be lost.
Sorry for all this, i just want to make sure its right first time!
What i could do is build up from the billet pipe using washers (making the last one a h/press washer - that would mean i'd have 2 h/press washers either side of the actual sender part.
If that makes sense?!
Old 01-09-2006, 10:40 AM
Mike Rainbird
Caraholic
I'll send you out some you fucking whinge-bag - PM me the address you want them sent to .
Old 01-09-2006, 10:48 AM
Franco
Franco's Avatar
Not whinging Mike, just trying to see where its all going wrong?!?!?
Have you changed the kit recently?!?
Old 01-09-2006, 10:50 AM
Franco
Franco's Avatar
Excuse the spelling in the pic, i was typing away like a madman!
Old 01-09-2006, 10:55 AM
Mike Rainbird
Caraholic
Franco,
Seeing as you confirmed that you got that in the first picture that Doug posted, I find it strange you're saying now that you didn't .
It's the small banjo, but not looped round into a "ring" yet - try Spec-savers .
I buy the kits in in bulk, and the first batch was like the picture Doug posted up, the second batch was like the picture I posted up .
Old 01-09-2006, 11:03 AM
Franco
Franco's Avatar
Why the change then?
I tell you for why, the billet tube & the aeroquip fitting do not seal flush with the sender unit (due to the lenght of the quip in my OLDER kit).
This is what i'm trying to factor out using a bloody rubber bung!
Quick Reply: Ahmed style fuel pump fitting kit.... MikeR maybe?
