Whats the max can a T34.48 can realistically make?
Old 31-08-2006, 01:32 PM
  #41
reality
reality's Avatar
That is one possibility Doug.. although 95% seems a bit high!
Old 31-08-2006, 01:49 PM
  #42
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
It IS only open at 2°, it is idling FFS .
The 95% duty cycle is on the top lines (FF). I can't remember exactly from what point, as it is 8 years ago, but at high rpm everything was FF .
However, the Pectel monitor recognises the coding and so displays the duty cycle of the injectors at their most open point , so that you can see that on this map it is 95%.
It displays this at what-ever throttle position .
I think you're getting confused with injector open time (ms).
As this IS throttle angle dependent.
Old 31-08-2006, 01:55 PM
  #43
Mike, he was taking the 2 degrees to mean it was at 2 degrees and was still putting in 95% at that point
  #44
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Originally Posted by Stavros
Genuinley no difference?
Noticably more top end?
Genuinely no difference with regards to spool up time.
It does hold onto the boost longer than the .48 but by how much i cant say because im too busy concentrating on the road
Old 31-08-2006, 01:59 PM
  #45
reality
reality's Avatar
Mike.. nevermind, it's off-topic. Kinda.
t34.48.. good for 340-350bhp if you have the fuel.
Old 31-08-2006, 02:01 PM
  #46
CossieRich
CossieRich's Avatar
its good for 385 bhp as Mike has already stated IF you have the fuel
Old 31-08-2006, 02:02 PM
  #47
Mike Rainbird
Caraholic
Actually, I have just learned something new . I ALWAYS thought that that was injector duty cycle, but I have just been reliably informed (thanks Stu ), that the duty cycle displayed on the Pectel monitor, is in fact for the boost valve . I always thought it was injector duty cycle . Therefore, I have no idea what my 803s were running -All I remember is they were FF everywhere on the top lines - Stu could help me out again what that would equate to ?
Old 31-08-2006, 02:05 PM
  #48
CossieRich
CossieRich's Avatar
Why is it labelled duty cycle if its showing reading for the boost valve
Old 31-08-2006, 02:07 PM
  #49
Mike Rainbird
Caraholic
Apparantly, its the duty cycle of the boost valve, as this is also a percetage entered....
  #50
Disabled Account
Disabled Account's Avatar
You've got to remember these are cheap monitors, cant expect accurate information from them
  #51
FPMSL @ Mike...BUT surely you was told that was injector duty?
Old 31-08-2006, 02:11 PM
  #52
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Actually, I have just learned something new . I ALWAYS thought that that was injector duty cycle, but I have just been reliably informed (thanks Stu ), that the duty cycle displayed on the Pectel monitor, is in fact for the boost valve . I always thought it was injector duty cycle . Therefore, I have no idea what my 803s were running All I remember is they were FF everywhere on the top lines - Stu could help me out again what that would equate to ?
Good old Mike R, always happy to hold his hand up if hes wrong. I Pm'd him so he could "Professionally backtrack" if required, but instead he just admits his error.
impossible to say what 255 equates to in the map although normally its around 16ms +multiplyers on a green base.
Its impossible to say as its subject to the following multiplyers.
WOT
Battery voltage Multiplyer
Coolant Multiplyer
Air temp multiplyer
And a few more accessible by all.
Not to mention another 10+ multiplyers most tuners wont have access to at all such as injector scaling and map value scaling.
  #53
Mike Rainbird
Caraholic
Phil,
I'm sure I was when I first got the monitor 12 years ago - I've always though it was injector duty cycle .
Next time I'm out in the car, I'm going to check it though, as obviously it should fluctuate with the boost curve .
Old 31-08-2006, 02:12 PM
  #54
It is accurate, the valves are cycled just like an injector. In fact, with air/air, it IS an injector.
Old 31-08-2006, 02:13 PM
  #55
..come to mention it i remember you told me your moniter showed duty cycle for injectors when i drobve it that time So had you best tell Billabong or did he know?
Old 31-08-2006, 02:15 PM
  #56
Phil,
When all is said and done mike, I could be wrong too.
But i am very confident i am not. And yes, the value will normally lower with boost pressure. The reading displayed does not alter with air injectors added and configured, so always reads high off boost, as per the bleed off method.
Old 31-08-2006, 02:17 PM
  #57
Porkie
Porkie's Avatar
Originally Posted by Stu @ M Developments
Good old Mike R, always trying wriggle and squirm out of being wrong and blaming others wherever possible .
I totally agree Stu...
Old 31-08-2006, 02:20 PM
  #58
Mike Rainbird
Caraholic
CUNT
Old 31-08-2006, 02:28 PM
  #59
Porkie
Porkie's Avatar
Twice in 2 days Mike... Can't wait till Rich pon Stumbles across this
Old 31-08-2006, 02:29 PM
  #60
Mike Rainbird
Caraholic
Revenge will be OH SO SWEET .
Old 31-08-2006, 02:30 PM
  #61
Disabled Account
Originally Posted by Porkie
........... Can't wait till Rich pon Stumbles across this...............
Neither can I , thats why i've just PM'd him a link
Old 31-08-2006, 02:31 PM
  #62
Mike Rainbird
Caraholic
Tossers . I'd have got away with it if it wasn't for you pesky kids .
Old 31-08-2006, 02:42 PM
  #63
...well i have just emailed Harvey to tell him to drum into Mike NEVER answer questions before consulting him again.
Old 31-08-2006, 04:10 PM
  #64
Billabong
Billabong's Avatar
LOL- what's any of this got to do with me??
Old 31-08-2006, 04:45 PM
  #65
RichardPON
RichardPON's Avatar
Ello ello ello - what's all this then?
Just about to log off, but will reply with some suitable put down comment later on............
Old 31-08-2006, 05:47 PM
  #66
Alpina
Alpina's Avatar
I run a T34 .48 on a Harvey Gibbs engine (complete spec as yet unknown) but allegedly the turbo has been fiddled with in some way, light blues, L8, genuine 500 i/c, 2 bar of boost dropping to 1.65 - the previous owner claimed 400 bhp, but I would guesstimate it to be around 380 ish, maybe 400 if I up the boost (which allegedly it used to run).
Not proven as yet on rollers, but thinking of doing it soon though to see what it really makes.
The car does go like stink, and people are astounded by how much punch it has for the spec, so who knows?!
Rammer Rainbird knows the car from old and has been in it in the last couple of years, so maybe he could comment?
Old 31-08-2006, 05:52 PM
  #67
Billabong
Billabong's Avatar
Mike, what are your dipswitch settings?
Old 31-08-2006, 06:00 PM
  #68
Tonks
Tonks's Avatar
good read this. gives me hope with my .48
Old 01-09-2006, 07:55 AM
  #69
Mike Rainbird
Caraholic
They don't seem to have any effect, so I don't think I have the correct manuel for my monitor
Old 01-09-2006, 08:05 AM
  #70
Mike does the one you have look like this:
Old 01-09-2006, 09:39 AM
  #71
Billabong
Billabong's Avatar
I found your settings later on yesterday on another post Mike, they were all set to BLONDE
Old 01-09-2006, 09:45 AM
  #72
Porkie
Porkie's Avatar
Old 01-09-2006, 09:48 AM
  #73
RichardPON
RichardPON's Avatar
FROFL
Old 01-09-2006, 09:51 AM
  #74
Andreas
Andreas's Avatar
Some years ago I asked Harvey about the Duty Cycle setting and if understood him correctly it wont display correctly on a L8, needs a P8 for a correct figure of Duty Cycle.
Old 01-09-2006, 10:47 AM
  #75
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
all the lad fookin asked was wot power,it would have been better if he stated injectors aswell,but i can tell u my car made 357bhp and 340lbs on the rollers t34.48 greens (803's) M.S.D chip + setup,so with l blues (or whatever) it must be more..... just the facts boys!!!!!!
Old 01-09-2006, 11:08 AM
  #76
Why must it be more with bigger injectors?
If the greens are providing enough fuel for the air consumed then why would bigger injectors make more power?
You do realise that (from a correct AFR) more fuel and the same airflow will equal LESS power do you?
Old 01-09-2006, 05:33 PM
  #77
CossieRich
CossieRich's Avatar
Becuase people think bigger is better unfortunately
Old 01-09-2006, 05:35 PM
  #78
Hybrid-Chris
Hybrid-Chris's Avatar
Porkie i take it the reason for this question is my add in the for sale section on GTR.co.uk got you thinking to much.
  #79
Andreas
Andreas's Avatar
Well, thats what the girl told me.
Old 01-09-2006, 05:37 PM
  #80
CossieRich
CossieRich's Avatar
Quick Reply: Whats the max can a T34.48 can realistically make?
