Boost increase
Old Aug 30, 2006 | 06:35 PM
Harrism's Avatar
Harrism
Default Boost increase
How do i this?
I have a Bleed valve attatched when i bought the car.. however i twisted it and the dropped like a stone even though i hardly turned it!
do turn twist the actuator as well?
(BTW I'm turning up to 20psi from 17psi on my stage 1 cossie)
Old Aug 30, 2006 | 06:36 PM
R4N SS's Avatar
R4N SS
I would suggest getting the fueling checked for det if you are gonna turn the boost up like that.
I assume this is on a cossie
Old Aug 30, 2006 | 06:39 PM
Harrism's Avatar
Harrism
yup, sierra 4wd..
My mate runs 20psi on similar setup and he's had it checked for knocking which was fine, i'll go get a check too
anyway any ideas? as the boost gauge is sitting offly low! wont drive it like this!
Old Aug 30, 2006 | 06:42 PM
Gary F's Avatar
Gary F
20psi on a stage 1 is that normal mines 20psi on stage 3
Old Aug 30, 2006 | 06:46 PM
gar mae's Avatar
gar mae
Bleed valves are always a bad idea, get it set up by a pro or your only going to be paying for a rebuilt engine!!
Old Aug 30, 2006 | 06:47 PM
ellicoss's Avatar
ellicoss
Just because your mates runs fine on the same set up dont mean yours will get it checked mate cheaper than a new set of pistons
Old Aug 30, 2006 | 06:51 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
don't run 20psi on a stg 1 , you will blow the engine to lots of little bits. Bleed valves are fine if used correctly, just means they are open to people to meddle with 15-16psi should be the absolute max you are running, and as people have said, if you want it faster, go and see a pro it will be MUCH cheaper in the long run Where abouts in the country are you?
Cossy Chris's Avatar
Cossy Chris
I always thought 15psi was the most on a stage1?
Old Aug 30, 2006 | 06:57 PM
Harrism's Avatar
Harrism
got myself a problem! how do i reset it to 15psi..
I knew i shouldnt have touched it!
I'm running greens, pipercross filter, uprated actuator, chipped stg. 1, mongoose 3.5"..
Old Aug 30, 2006 | 07:04 PM
gar mae's Avatar
gar mae
Welcome to the world of bleed valves!!!
Old Aug 30, 2006 | 07:11 PM
RWD_cossie_wil
right, turn the bleed valve right down, so its fully shut, ie so NO air is gettin past it. Then go and find a nice empty stretch of road, and get the car to 4000RPM in 4th gear, put your left foot on the brakes, gently press them and floor the accelerator. You should now be getting full load with the car being held back- boost should be at its peak, and it wants to be 15psi max. If its lower than this, open the bleed valve slightly and repeat the test. If it goes over 15psi once you have opened the valve, back off immediatly and turn the bleed valve back down
Old Aug 30, 2006 | 07:15 PM
Harrism's Avatar
Harrism
Cheers, i dont need to touch the actuator then?
Old Aug 30, 2006 | 07:21 PM
RWD_cossie_wil
don't mess with the actuator unless its making more than 15psi with the bleed valve fully shut- if it is, then take some of the pre-load OFF. If you are running greens then you might be able to run more boost, check the part numbers on the side of them, are they dark or light green? light greens should end in 355, dark greens in 803. However, please don't play with more than 15psi until you get it set up ,as you have no way of knowing if the fuelling is correct, and £100 for a rolling road tune is far far cheaper than a new engine
Old Aug 30, 2006 | 07:33 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Your boost is pretty low for a stage 3.
Old Aug 30, 2006 | 07:43 PM
Harrism's Avatar
Harrism
So am looking to iron out the actuator too, if it doesnt make 15psi or more i leave it, if it makes more say 15psi what do i do?
Old Aug 30, 2006 | 09:16 PM
reality's Avatar
reality
You shouldn't be running a stage 1 chip with green injectors anyway!! Are you sure you know what you've got?
Old Aug 30, 2006 | 09:31 PM
RWD_cossie_wil
mate from the sounds of things, the best thing you can do is take it to a specialist ,saves any messy blow ups and you know it will be %100
Old Aug 30, 2006 | 09:33 PM
space hoppers's Avatar
space hoppers
totally agree that dont make sense at all
Old Aug 30, 2006 | 11:11 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Harrism, Assuming scaatland is scotland take it to AVA, they'll sort the car out no problem, if you need the phone number to book it in then let me know.
If you blow it up, i'll buy it off you for a score
Old Aug 30, 2006 | 11:31 PM
As everyone else has said, greens and a stage 1 doesnt make a lot of sense.
Get it looked at by someone who knows what tehy are doing.
Old Aug 31, 2006 | 10:22 AM
Harrism's Avatar
Harrism
I have the light greens.
Think i will just take it to AVA and get it looked over and RR . .
Iron out everything
Old Aug 31, 2006 | 10:27 AM
lukeytheduke's Avatar
lukeytheduke
hi, i run 15psi on my stage 1, 20s not good mate
Old Aug 31, 2006 | 10:36 AM
vroooom ptssssh
It Wasnt Me!
Iron out everything
Thats the sensible thing to do
AVA - 0141 848 5257
Old Aug 31, 2006 | 11:20 AM
Harrism's Avatar
Harrism
Iron out everything
AVA - 0141 848 5257
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
