can a 1600xr3i head bolt to a zetec block
hi all
is it true that you can bolt
a 1600 xr3i/rs turbo head to a 1800/2000 zetec block
if so whats need to be able to turbo it.
cheers
cheers
same bolt pattern but there is much more to the conversion than that!
you need to adapt cvh water pump to the block, spacers on the pulleys, rear mount.
1800/1600 Zetec sump too.
To turbo it you need breathers and oil drains
it's covered in here many times
google ZVH conversion
Jack and the Beanstalk
15-08-2015 04:27 PM
