handsfree users - mic location?
ive got a CW-&k (or whatever its called) in my sierra. the mic is up by the map reading lights
trouble is people struggle to hear me properly![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
where do you have yours?
JIM
that is the correct position for the mic.
The problem you have is your car is noisy/loud because it is an older car with probably a loud exhaust, running on over sized tyres for that car. remember it came out of the factory with different wheels/tyres and thus the road noise will be different.
Also it might pay to check to see if the mic is on something that is attached to the rook of the car- it may be better if it is moved on to the roof lining using a bit of velcro, while you're at it check the air vents are not blowing at or towards the mic.
The nokia mic has 3 recomended positions.
1 Near the light on the roof of the car
2 Drivers side A pillar trim
3 Ontop of the dash board above/on the instrument binicle.
I have only ever seen position 3 used once- on all other cars Position 1 is about 90% and position 2 10%
Hope this helps.
Jake
Hope this helps.
Jake
i have the same kit, my mic is in the same place and peeps hear me fine
never had any probs, just to troubleshoot the problem have you tried another phone?
JK12
33
26-04-2021 12:09 PM
23
12-09-2015 12:56 PM
track.focus'd
12-08-2015 05:53 PM
