My grief with SCS and Harvey Gibbs
#81
Originally Posted by Cossie Helen
Originally Posted by "angel45
electrics, Fuel filter srapped to my anti roll bar (via 1 cable tie)
Think i will stick with Mark
don't blame you
#82
Originally Posted by MAD YUM
Originally Posted by angel45
Fuel filter srapped to my anti roll bar (via 1 cable tie)and lots more i wounldn't even piss on the cunt if he was on fire imo
Dean told me about this when he had your car in
Thats top service for ya
Hello
its all falling into place so soon [/quote]
mate when its done you going to have to take me out for a spin fella
#83
Here is an extract from the Dti site:
Supply of Goods and Services Act
The Supply of Goods and Services Act 1982 requires traders to provide services to a proper standard of workmanship. Furthermore, if a definite completion date or a price has not been fixed then the work must be completed within a reasonable time and for a reasonable charge.
Also, any material used or goods supplied in providing the service must be of satisfactory quality.
The law treats failure to meet these obligations as breach of contract and consumers would be entitled to seek redress, if necessary through the civil courts.
#85
Mate I told you, shame thing happened to me with Spades old engine, Harvey's customer service seems to stop @ mike and his regulars it seems
My car when it left Harvey and it was a timebomb waiting to happen, and after i paid him he had no interest in sorting it out even tho i had just spend 20K with him
#86
As mentioned before, a 400bhp highly tuned YB (yes i know people go further but thats still nearly DOUBLE the original output) being "fit for purpose" cant be considered alongside the sort of milages you would expect from a "normal rebuild"
Used hard enough even the worlds best ever 400bhp engine could easily be killed in 5,000 miles.
Try entering the lemans 24 hour with the same one a few times and you will see what i mean
Thats not saying i think only 10K road miles is acceptable, i dont particuarly for how i drive on the road and would expect more, but its VERY dependant on how its driven.
If the owner could prove it was NEVER used to break a speed limit it might be fair to class it as a road engine not a race one i guess
#87
As I have said already, how can Harvey be blamed for faulty loom / sensors / disconnected air injectors . He supplied the engine ONLY and did NOT fit it in the car . This has happened over a period of 15 months and in excess of 9,000 miles .
#88
Originally Posted by "Mike Rainbird
I was just providing an explanation as to why Harvey wouldn't stand by the engine, he has no idea of how hard the car was driven with it running this amount of boost. The pistons have been idependently checked by 2 other engineering companies and the reason the rings nipped up is due to it running lean. This can only be down to two things - too much boost or not enough fuel. You know and he knows that at some point the car was run with unlimited boost, whether this caused the failure NO-ONE can say, as there were so many things that unfortunately went wrong.
[b
[b
As i have said, EA would have noticed my car hitting unlimited boost, im sure that they are qualified enough for that !! [/b]
But if it had been disconnected for some time and the car been driven, firstly i would notice secondly the car would have detted and someone like Ahmed would notice that im sure.
[[/quote]
You took it to Paul Hills first and THEN Ahmed, but haven't explained why you did this, if everything checked out okay by Paul?
I have explained this, but i will explain again. Harvey wrote on my receipt, check fuelling, so i popped it along to Paul to check the fuelling throughout the rev range as Ahmed was booked up for a while so i got one step ahead of myself, they didnt do anything else and i can get that in writing from Paul Hills, it was then taken to Ahmed for the final set up as recommended after i had paid the money for the engine.
As I stated, Ahmed wouldn't notice any det with the boost control connected. With regard to the boost on the rollers, very few can replicate the load required to get the same boost that is seen on the road, so it may have been down to this - I can only comjecture about this.
But if it wasnt connected and i had been driving it about, surely Ahmed would have noticed something wasn't quite right as i had driven the car, just not too much.[/quote]
Because you have threatened to take him to court, his solicitor has recommended that he retain these for evidence.
So, you're saying he refuses to give me back the parts WHICH ARE LEGALLY MINE ?
You wait until the Inland Revenue hear about his cash payments then, thats just the start of it.
Actually you have just shot yourself in the foot here by admitting that this was changed, as EVERY SINGLE TUNER on here will tell you that if that nut is removed, the tension on the valve springs will cause the cam to jump back a tooth and you wouldn't have even noticed unless you KNEW this happens .
I haven't shot myself in the foot, this was yet another disaster waiting to happen, the guy that changed it for me was the top mechanic at Brands Hatch rally school, his job was to build and maintain cossies, he is currently in the process of building his 2nd one, his work is first class and i trust him more than i would Harvey after all this fiasco !
It may not have been sufficient to cause IMMEDIATE catastrophic failure, but without having stripped the engine down, it would have been IMPOSSIBLE to make that statement....
One minute it is, then it isn't....
Also regarding the supposed head-gasket failure on you way home, I am confused about that, as you said that Harvey didn;t have time to change your bearings OR your brake discs, and he also refused to road test it hard until the loom issue was addressed, how the hell did YOU drive it hard enough to get a WRC gasket to fail without doing ANY other damage to a freshly built engine? [/quote]
Nothing supposed about it, just more shoddy workmanship, imagine how i felt, like i have said, i dont even think that Harvey builds them himself, so other bloke does afaik and whether he is any good or not i dont know, but it doesnt seem so.
#92
Thanks for that, Harvey has got all this info from me, basically, i have a right to a partial refund even after 6 years let alone after just a year
#95
#97
#98
Your joking arent you !!
NO ONE HAS TAMPERED WITH THIS ENGINE,
With regards to the cam timing being out, thats absolute bollox Mike, a locknut was changed as the one Harvey put on it nearly fell off...
#101
Location: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
These are honest niiave questions: would you be able to tell if the timing was out? (even, what seems to me who knows nothing, a small amount) as it was the nut replaced would it be standard practice to check the timing was still ok? (as anything to do with cams/belt/timing could put it out?)
Had the air injector wire ever came off? Would you be able to tell when driving it was running unlimited boost? (if you had a boost gauge wouldn't that go up by silly amounts? You must have an idea what it safe level it should run?)
If the sensors were faulty it would still run fine? Or wouldn't it be noticeable? (when the 4x4 crank sensor went it wouldn't start at all)
Not that its any of my business at all, just trying to understand (maybe it could help people in the future)
Z
Z
#103
Caraholic
[b
[b
SORRY FOR CAPITALS . AS I SAID NOT ON THE ROLLERS, THEY CAN'T LOAD THE CAR UP ENOUGH TO PRODUCE THE BOOST.
HOW CAN HE NOTICE SOMETHING THAT ISN'T THERE ANYMORE? ONCE IT'S STOPPED DETTING DUE TO THE BOOST CONTROL BEING RECONNECTED, AHMED WOULDN'T NOTICE ANYTHING. THE ONLY WAY HE WOULD HAVE BEEN ABLE TO TELL YOU IF IT WAS DETTING WAS TO RUN IT WITH THE BOOST CONTROL DISCONNECTED AND THEN CHECK IT. BUT IT WOULD BE OBVIOUS THAT THIS IS WHAT WOULD BE HAPPENING WITH THIS DISCONNECTED, AS IT WAS GETTING UNLIMITED BOOST. AS THIS WOULD HAVE ONLY BEEN HAPPENING IN SHORT BURSTS (DEPENDING ON YOUR DRIVING STYLE), IT WOULD NOT HAVE BEEN ENOUGH TO LEAD TO AN INSTANT CATASTROPHIC FAILURE (UNLESS THE CAR WAS HELD FLAT OUT).
WE KNOW THAT IS NOT STRICTLY TRUE, AS YOU HAVE ALREADY STATED HE ALSO CHANGED THE CODING IN THE CHIP TO DISPLAY "ENGINE ADVANTAGES" ON THE CHIP, SO THAT WAS SOMETHING ELSE HE DID AND NOT JUST THE FUEL CHECK, AS THIS CAME UP ON AHMED'S PECTEL . WHY WOULD HE ENTER ANY INFO IN THE CHIP IF HE JUST DID A FUEL CHECK .
PLEASE EXPLAIN TO ME HOW YOU THINK HE WOULD BE ABLE TO?
HE HAS BEEN ADVISED TO RETAIN THEM AS EVIDENCE, AS THEY SHOW CLEARLY THAT THE ENGINE HAS BEEN RUN LEAN AT SOME POINT. WHETHER THIS WAS DUE TO THE UNLIMITED BOOST OR THE FACT THAT THE SENSORS OR LOOM WAS AT FAULT, IT IS IMPOSSIBLE TO SAY. HOWEVER, IT WASN'T ANYTHING THAT CAN BE CONTRIBUTED TO HIS ENGINE BUILD.
WELL IF YOU DON'T BELIEVE ME ABOUT THE INLET CAM JUMPING BACK A TOOTH WHEN THIS NUT IS REMOVED, ASK ANY OTHER TUNER ON HERE....
THAT IS THE PROBLEM, YOU HAD FOUR SEPERATE ISSUES:
1. UNLIMITED BOOST
2. FAULTY TPS SIGNAL
3. FAULTY PHASE SIGNAL
4. INCORRECT CAM TIMING OUT BY ONE TOOTH
TRYING TO PIN THE BLAME ON ONE PARTICULAR THING IS IMPOSSIBLE, AS THEY ALL COULD / WOULD HAVE CONTRIBUTED TO YOUR PROBLEM .
Nothing supposed about it, just more shoddy workmanship, imagine how i felt, like i have said, i dont even think that Harvey builds them himself, so other bloke does afaik and whether he is any good or not i dont know, but it doesnt seem so.[/quote]
SO WHY DID YOU NOT ALLOW HARVEY TO TAKE THE CAR BACK WHEN HE OFFERED TO PICK IT UP FREE OF CHARGE? YOU SEE WHEN HE BELIEVES THE PROBLEM COULD BE DOWN TO HIM, HE REACTS TO IT. WITH THE SENSORS, BOOST CONTROL & CAM TIMING, HE KNEW IT HAD NOTHING TO DO WITH HIS ENGINE BUILD....
#104
#106
I can get several mates to testify that i was there when Buzz Aldrin stepped onto the moon
#108
Have got the two intercoolers i need now.
This post fucking RULES for advertising
anyone want to buy an Alfa 146 twinspark while im on a roll?
#109
No bother but if i had no boost control, surely it wouldnt need loading up to produce the boost ?
But surely, if i have no boost control, it wouldn't drive properly at all which i would notice IMMEDIATELY if i put my foot down which is a rare occasion for me, but it does happen..
Erm, no, no values in the ECU were changed at any time, fact.
As in between getting the fuelling checked and mapping was a short time, but enough for the engine to go bang if it was hitting silly boost when it was driven.
Thats fine, if he refuses to give the pistons back which as i say are legally mine, then thats another string to my bow.
Its not a case of disbelieving you Mike, it may well happen, i just find it VERY hard to believe knowing the guy that changed it for me !!
1. UNLIMITED BOOST
Like i say, the car was fine when it left Ahmed, everything was perfect, so it seems VERY suspect that all the above was wrong when it was given a clean bill of health.
SO WHY DID YOU NOT ALLOW HARVEY TO TAKE THE CAR BACK WHEN HE OFFERED TO PICK IT UP FREE OF CHARGE? YOU SEE WHEN HE BELIEVES THE PROBLEM COULD BE DOWN TO HIM, HE REACTS TO IT. WITH THE SENSORS, BOOST CONTROL & CAM TIMING, HE KNEW IT HAD NOTHING TO DO WITH HIS ENGINE BUILD....[/quote]
Because i was and am fed up with keep taking my car back time and time again after all these problem with the engine, why did the head gasket go, why was there oil pissing out of every corner, why did the cap snap, it all adds up to a very suspect build to me and i would rather someone i trust sort the car out, i think thats fair enough.
1. UNLIMITED BOOST
#110
Matt, kindly fuck off you twat
#111
Caraholic
As I said Rich, I do feel for you.
I had a similar issue, I was ragging the car (my old Sierra) and the vacuum hose came off the fuel regulator (therefore meaning that it didn't know to supply more fuel pressure with the rise in boost ).
After hard acceleration runs at three figure speeds, I could feel something wasn't quite right and pulled into petrol station, only to notice the vaccum hose for the regulator was hanging off . I "thought" I was lucky, as there was no smoke or anything, so I assumed I had got away with it . But later that night on a "high speed" run, number two and three pistons nipped up (same as yours), and this was because the "damage" had already been done with the lack of fuel pressure, but at the time it was not catastrophic damage until I compounded it by ragging the shit out of it .
Regarding the unlimited boost issue, what boost exactly was your car running AFTER it came away from Paul Hills and before Ahmed saw it?
#112
It was holding slightly more boost but it was only a base map that Ahmed put in it, they did not change the ECU's programme, that's a fact Mike, call Paul Hills and ask him.
Really, its not about money, if i was short of dough i wouldn't spend what i have, its more a case of decent customer service and assistance which i feel have been very negative from day one and i feel i should be compensated for what he has charged me and the faults that i have had.
#113
Edited to add, I have no preference on the outcome of this case but would obviously like to see the correct outcome acheived.
#114
You cant really prove your pal didnt fuck the cam timing up so it's hardly fair slagging Harvey for that Case closed IMO
#115
So the real issue here is.. "faulty ancillary destroyed my £8,5k engine"
Surely you have a boost gauge?
It's a bit like blaming a builder your house burnt down because of a faulty gas fire you put in after the build
#116
He isn't a MATE as such, he is a neighbour who knows his Cossies inside out, you can even ask DaveEscos about his quality of work.
Now jog on fella..
#118
#120
Sorry to hear all your grief m8
but you aint gonna win on this board..
Just one thing though how do you know that the pistons he is keeping as proof are the ones that came out of your car????
Whats he do mark em with a felt tip pen when he 1st put them in
And as for the air inj wire being loose??
for all we know it may of been lose for what 5 mins or 3 weeks
