RS500 v 2wd engine - differences.
Old Aug 21, 2006 | 08:00 PM
peteh's Avatar
peteh
Default RS500 v 2wd engine - differences.
Hi all, anybody have a link or know the differences between the two, i know the blocks are stronger, but im just wondering about CR, heads ported, what cams they use that sort of stuff
any help ta
Old Aug 21, 2006 | 08:43 PM
peteh's Avatar
peteh
god on second page already
Old Aug 21, 2006 | 08:50 PM
topaz's Avatar
topaz
1K+ Super Poster!!
http://www.rs-500.com/
some info there
Old Aug 21, 2006 | 09:15 PM
PAUL S's Avatar
PAUL S
Internally they are exactly the same, whether it be cams, pistons, valves, crank, rods etc its the bolt ons that make the difference and the thicker walled block
Old Aug 22, 2006 | 06:56 AM
Mr RS500's Avatar
Mr RS500
A.K.A.
WRONG ,,,
Old Aug 22, 2006 | 11:35 AM
PAUL S's Avatar
PAUL S
Originally Posted by NORTH YORKS RS SPARES
A.K.A.
WRONG ,,,
give examples then as to how I am wrong in order to help the thread poster
identical parts between 2wd and RS500 engine are:-
Pistons
Rods
Crankshaft
Front Crank Cover
Head Gasket
Big ends and Mains
Bearing Caps
Valves
Cams
Cam Caps
Hydraulic tappets
Combustion Chamber volume
Cam Cover
Cambelt
Cambelt cover
Injectors
Coil
Leads
Inlet trumpets - Rs500 version was slightly machined at the mouth about 5mm in after casting and had two dowl holes drilled into it but casting is the same
Exhaust Manifold
Flywheel and clutch
Crank Pulley
Sump
Distributor
Engine arms and mounts
Modine
Breather set up
Idle speed control valve
throttle position sensor
crank sensor
all pulleys
map sensor
amal valve
The only different parts were :-
block - but internally the same - and could be swapped for a normal 205 and still work fine at normal outputs
turbo
Plenum outer body to accept further 4 injectors and throttle body
Upper fuel rail to allow extra take off point to the extra injectors
Fuel regulator - to allow twin inlets
3 bolt mounting point for the revised thermostat housing - other than that the casting is as per 2wd
water pump
bracket for the revised location of the amal valve
turbo damper
and a few minor odds and ends like air filter top, L1 ecu slightly modded etc
All first hand fact not pub talk - I have personally stripped and rebuilt every version of the YB engine inc RS500, only one I have still to play with is an EECV late escort spec one
To give you an idea of similarity you could take out the engine with all bolt ons fitted from a 3dr Cosworth and an RS500 swap them over refit them in the different shells - plug the looms back into the connectors and they would fire up and run fine in the wrong car
I am a Consultant Quantity Surveyor with no business connection to Cosworths at all so lets see if the "experts" know more than me
Old Aug 22, 2006 | 12:01 PM
Tangodeltasierra3's Avatar
Tangodeltasierra3
Hehe go for it Aka.
Old Aug 22, 2006 | 12:21 PM
That's gotta hurt paul if he is right
Old Aug 22, 2006 | 12:49 PM
topaz's Avatar
topaz
1K+ Super Poster!!
pretty sure the oil pump is different too
Old Aug 22, 2006 | 12:56 PM
_DAN_'s Avatar
_DAN_
Yoon
That's gotta hurt Paul if he is right
Old Aug 22, 2006 | 02:20 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
the 3 door engine is different to the 2wd sapph engines !
Old Aug 22, 2006 | 02:57 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
it is
Old Aug 22, 2006 | 02:58 PM
Dirty Harry
Super Moderator
it is so is the water pump and thermostat housing
Old Aug 22, 2006 | 03:01 PM
PAUL S's Avatar
PAUL S
spot on - but similar to a 4x4 one
I rattled that list off from the top of my head so missed a few things.
Turbosystems - the only difference I believe is that the later 2wd saffs had a 3 bolt thermostat head but the early ones were the same as the 3dr but all 2wd used the 2wd thermo housing regardless
I was also told that the 500 odd engines that were pulled out of the 3drs when they were converted to 500 spec were re-used in the 2wd saffs at the start of production
Happy to be proved wrong though
Old Aug 22, 2006 | 03:03 PM
The DIVA's Avatar
The DIVA
He`s pretty damn close.......
Oil pump and spraybar are different(for better oil spray under pistons)
Thermostat housing is a one off(Quite similar to 4x4 but not the same)
Old Aug 22, 2006 | 03:11 PM
Mr RS500's Avatar
Mr RS500
Its not hurting
He says they are the same
Oil pump is also a one off in a 500 ,,as said above
any more i wonder
Old Aug 22, 2006 | 06:23 PM
Boost Junky's Avatar
Boost Junky
Don`t the 500`s run a baffled sump too?
Old Aug 22, 2006 | 06:39 PM
Disabled Account's Avatar
Disabled Account
The RS-500 exhaust manifold is sleeved down in size..............well, they do according to this:
From this book:
Old Aug 22, 2006 | 06:43 PM
Dirty Harry
Super Moderator
it isnt mate
Old Aug 22, 2006 | 07:25 PM
PAUL S's Avatar
PAUL S
Originally Posted by Doug Stirling
The RS-500 exhaust manifold is sleeved down in size IIRC
thats the downpipe not the manifold =- all ford did was weld a washer in it to try to control the back pressure from the T4
Old Aug 22, 2006 | 07:33 PM
Disabled Account
AKA, I was only going by what I've read (see the edited post above)...........But if Pete RS Specialist says that manifolds are not sleeved, then I am inclined to believe him.
Old Aug 22, 2006 | 07:58 PM
Dirty Harry
Super Moderator
did I say there wasnt sleeved ?? I dont think so as they are
Old Aug 22, 2006 | 08:05 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
down pipe was sleeved,not manifold,
someones going to say the head was different as well arent they.
Old Aug 22, 2006 | 08:31 PM
Mr RS500's Avatar
Mr RS500
Yes the head has one little diferance
Old Aug 22, 2006 | 08:33 PM
PAUL S's Avatar
PAUL S
I thank you sir
Going back to the start, essentially they are the same animal, parts from an RS500 engine can be replaced with the equivalent 2wd component and vice versa.
Old Aug 22, 2006 | 08:44 PM
Mr RS500's Avatar
Mr RS500
The post didnt ask if you could change the engines over without any mods ( altho you can ) it asked if there was any diferances and there is quite a few
Old Aug 22, 2006 | 08:46 PM
peteh's Avatar
peteh
but what i don't understand is..............
only joking, just id been offered a bare engine and wondered if they were worth anymore than a standard 2wd engine
Old Aug 22, 2006 | 08:48 PM
Mr RS500's Avatar
Mr RS500
Pete
they are worth a lot more than a std engine ,,about an extra 1k is a rough guide
Old Aug 22, 2006 | 09:42 PM
900ss's Avatar
900ss
RWD Racer
Frt cast turbo damper lug area wasted away?
SmudgerByName
52
Jul 28, 2016 06:14 PM
Oct 9, 2015 07:38 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
