Is a 7.4.1 comp to low to run a T34.63?
Old 17-08-2006, 09:06 AM
peteh
peteh's Avatar
Default Is a 7.4.1 comp to low to run a T34.63?
Just a general question i need answering please
cheers.
Old 17-08-2006, 09:07 AM
Graceland
Team HOTHOT!
Graceland's Avatar
If you are thinking in terms of lag, then compression ratio has no effect on turbo-lag
Old 17-08-2006, 09:09 AM
peteh
peteh's Avatar
Im thinking the amount of air produced by the engine would be to great/little (not sure which) for the turbo?
I haven't a clue to be honest
On what engine?
If its a YB, then yes i would say thats too low unless you reguarly take a piss in your petrol tank.
Old 17-08-2006, 09:12 AM
peteh
peteh's Avatar
Yeah cossy, just thinking what my options are with my engine (for sale) if the main engine doesn't sell.
Old 17-08-2006, 09:14 AM
It will work fine, its not that it wont run or anything like that, compared to standard CR it will just feel flat off boost and make a little less power at the top end.
no big deal.
Old 17-08-2006, 09:16 AM
Ryan
Ryan's Avatar
got a nice new t38 for sale if he's interested
peteh
peteh's Avatar
would a T4 suit it better? but then there's lag isn't there?
peteh
peteh's Avatar
could well be
Old 17-08-2006, 09:19 AM
Suit it better for what?
Old 17-08-2006, 09:26 AM
peteh
peteh's Avatar
for the engine spec.
Old 17-08-2006, 09:30 AM
The engine spec would better suit a T4 turbo than a standard engine would suit a T4, but that doesnt mean bolting a T4 onto it will give you something pleasant to drive, it all depends on what you are after, and unless its 500bhp or so, i cant see why you would want to fit a big laggy T4
I would worry most about ending up with an engine and turbo that suits your driving.
Old 17-08-2006, 09:33 AM
peteh
peteh's Avatar
I don't want 500bhp far from it , wana fast street /quater mile car
punchy and responsive most of all, not into top speeds and that.
Old 17-08-2006, 09:35 AM
...that comp and turbo is FINE Pete
Its the old school way of doin things..where a T4 engine could only be 7.2-1 or less
Nowadays 7.4-1 is GT35 territory
Old 17-08-2006, 09:36 AM
Then IMHO its not a suitable compression ratio and i would wager the ports in the head are too big as well.
You would be better off for what you want just swapping it for a standard engine!
Old 17-08-2006, 09:37 AM
You think 7.4:1 comrpession is going to be "punchy and responsive" on a T34 compraed to standard compression?
Old 17-08-2006, 09:38 AM
peteh
peteh's Avatar
can't find one of them though well nobody that wants mine anyway.
...oh and before anyone spouts more "in theorys" i have had most comp ratio and turbos ..and the current one just so happens to be the spec your after Pete....feels a lovely combo to me bizarrely
Old 17-08-2006, 09:41 AM
Chip i talk from experience not books
..plus i never said it would be as good as std comp as that never arose in the conversation..he was asking if it would be ok...and IMO yes it will as i have experience..
peteh
peteh's Avatar
sorry phil , explain abit mate, your new car is running a similar spec ti mine with a T34.63?
Old 17-08-2006, 09:42 AM
He doesnt want "ok" he wants "responsive and punchy"
Old 17-08-2006, 09:45 AM
Hi Pete yes....the engine was made for 600bhp so basically its a case of just putting bigger injectors and turbo on it and remap of course.
Its a solid 400bhp with the T34.63 and is setup to perfection and very nice....you wouldnt be dissapointed,you could go bigger turbo but it depends what you want...in my EXPERIANCE it feels nice
Old 17-08-2006, 09:46 AM
peteh
peteh's Avatar
Thank you phil, the wise man has spoken
Old 17-08-2006, 09:48 AM
Ryan
Ryan's Avatar
let me know about the t38 pete if your interested
Old 17-08-2006, 09:49 AM
Rick
Rick's Avatar
I'd say it would be fine. I've got a t34 on a 1600 with similar ish compression ratio, and it drives fine off boost. You could have a nice 2.5 bar spike in the mid range for some serious acceleration
Old 17-08-2006, 09:51 AM
peteh
peteh's Avatar
here sounds like a man with experiance
Old 17-08-2006, 09:53 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
You want a 0.48 A/R T34 then if you want punch AND response.
Old 17-08-2006, 09:54 AM
peteh
peteh's Avatar
NEXT QUESTION
what cams? got BD16's at the mo
Old 17-08-2006, 09:57 AM
Mike Rainbird
Caraholic
STANDARD for punch AND response .
Old 17-08-2006, 09:58 AM
yours feels nice because you have a good map on it and probably havent had on a standard compression engine with a t34 on it.
If you had EXPERIENCE of both back to back you would realise that
It will work, but its far from ideal.
Old 17-08-2006, 10:00 AM
...or MAD secret cams seem to work quite well
..becareful if you choose .48 as from MY experience i didnt like the way the power drops off before the limiter... .63 to the limiter baby no worries...about a 500rpm difference.
Old 17-08-2006, 10:04 AM
Mike Rainbird
Caraholic
That is correct .
But a 0.48 housing on a 2wd car, gives more consistant drag times as you can get the launch right more easily...
I used to able to REGULARLY punt out 12s quarters with my 0.48 A/R equipped car (over ten in one day before), whereas with the 0.63 A/R, it would only be possible if the launch was perfect, as it was much more all or nothing (bog or wheelspin city).
Old 17-08-2006, 10:09 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Persoanly, i would use the .55 housing as it can hold on to the boost that much longer up the rev range over the .48.
BD14 inlet and 2.5 bar spike of boost in the mid-range. you wont be disappointed
Old 17-08-2006, 10:14 AM
Excuse me??? This MAD engine is running an off the shelf Ahmed map Same as my std comped t34 .48 map ...i have no experience of a LIVE mapped car except my M3 ....and nor do the majority of users here...so a very poor attempt at a dig
Old 17-08-2006, 10:22 AM
peteh
peteh's Avatar
this ok with double valve springs?
Old 17-08-2006, 10:23 AM
I cant see why not
Old 17-08-2006, 10:25 AM
Mike Rainbird
Caraholic
You don't need them with standard springs...
Old 17-08-2006, 10:26 AM
peteh
peteh's Avatar
Thanks phil, your being surprisingly helpful
Old 17-08-2006, 10:34 AM
Pete i actually KNOW about YB engines contary to popular beleif I have built a couple and specced them too with a little help from my friends I dont however profess to know everything to earn internet brownie points,i know what i need to know ONLY..anything more is a waste
Old 17-08-2006, 10:35 AM
peteh
peteh's Avatar
just i don't wana take the head off
Quick Reply: Is a 7.4.1 comp to low to run a T34.63?
