Strange electric headlight problem - any ideas?
Redumbdancy
On my Mk3 Fiesta both headlights work fine on dipped beam, but only the left hand side worked when switching to full beam
This is strange as they both use the same bulbs - ie dipped and full beam elements within same bulb.
I have swapped the bulbs over and still no change.
Also played about with the wiring and no change either - any ideas? This problem started totally out of the blue
diagonsis is easy...
Check for power (12v) both sides.... so check fuses as well.
Check grounds.
That should allow you to find the problem, be it a ground or a stalk!
Alex
Check grounds.
Alex
Redumbdancy
Check grounds.
Alex
Check grounds.
Alex
What the common problem with the stalks exactly - the cars a mk3.5 to be specific (and i have heard somewhere thier stalks are different from mk3's)
Stu @ M Developments
41
21-08-2015 06:47 AM
Palethorpe01
15
18-08-2015 06:09 AM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
