long stud fitting question
Old Aug 13, 2006 | 11:46 AM
GUZZLER's Avatar
GUZZLER
Default long stud fitting question
Should really pull my finger out & finish thin engine anyway, i think the missis has put my long stud instructions is a safe place......
therefore i just need to check which way round the stud go's & the torque,
one end of the stud is thicker, is this the end that go's into the block? also i take it the o ring sits in the groove in the centre of the stud? Sorry for my ignorance but its the first time i've used long studs
Old Aug 13, 2006 | 11:54 AM
xr4x4rs's Avatar
xr4x4rs
yes the o ring goes in the groove of the stud
this is due to when the block is machined for long studs they go through the water jacket of the bores i was told
also arnt the threads different each end so will only go one way
could be wrong though
Old Aug 13, 2006 | 12:03 PM
GUZZLER's Avatar
GUZZLER
the threads are the same, i belive the torque settings are lbs/ft then 90 degrees, then the nuts are 115-120 lbs/ft
Old Aug 13, 2006 | 12:04 PM
xr4x4rs's Avatar
xr4x4rs
havnt a clue on the torque settings unfortuantly mate
my studs are still wrapped up
Old Aug 13, 2006 | 12:06 PM
GUZZLER's Avatar
GUZZLER
thats were mine may go for a few more weeks
Toe Knee
Aug 23, 2015 08:31 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Perfmr2
Aug 6, 2015 07:30 AM
Billy_RS
Aug 3, 2015 08:43 PM
lockie
Jul 31, 2015 10:03 PM
